New system won't post
sdy284
ok, I've got the following parts:
PCP&C 750W Silencer
i7 920
ECS X58B-A rev1
Corsair Dominator 3x2Gb 1600Mhz TR3X6G1600C8D
Sapphire 4890 2Gb Vapor X
Seagate 160gb HD
Samsung DVD Burner
Right now I have it sitting on a box outside of the case to eliminate any grounding issues. The only way so far i've been able to get it working is to put 1 stick of RAM in the farthest slot away from the CPU, and clearing the CMOS.
Once I do this, it will boot, and then it will show an error message that I don't have a hard drive, but then when I go into the BIOS, it shows my HD on SATA 1. But sadly, this isn't my problem I don't think because when i hit F10 to save & restart, it basically goes into an endless boot, reboot cycle, ultimately the little POST display LED's land on 00 & AA which from what i've read online indicates everything is working normal (but in this "normal" state nothign is displayed on my screen)
When i power down & try to power on after this, the POST display ends up displaying 85
I can't for the life of me figure out what the damn problem is. Originally I had some Chaintech Apogee 1866 memory, but the voltage on that was pretty high and i thought that could've been the problem. This Corsair stuff was supposed to be my fix but it doesn't appear so :(
ALso, i've tried setting the ram speed manually in the bios to both 1333 and 1600 (as well as setting the uclock to 2666 and 3200) and that didn't work either
Any help you guys could be on this would be appreciated!!!
jesus, i've tried everything i've found on the web for this board and nothing works
Is first boot using all defaults in BIOS? If not try the LOAD DEFAULTS option in your BIOS and see if that boots up.
Do you have another PS to test with? Could just be that you got a bad board and need to RMA but I would test the PS first just to save time / head ache (even if its just a crappy old 300w PS).
Well now it doesn't seem to want to boot @ all.
Another thing this thing does is then i press the power button, everything on the mobo powers up, GPU fan goes full speed, etc... etc.
Then it shuts off for ~2seconds and comes back on. At this point it will either
A) Power on everything & the GPU fan runs full speed. When it does this, then it won't boot.
B) Power on everything & the GPU fan runs slow. When it does this, then it boots and I can get into BIOS
I'd touble check the memory voltage. High end memory sometimes won't boot at default voltage.
I have had this happen to me before, ended up being my vid card wasnt seated right. Reset your CMOS, I usually pulled my battery out for like a half an hour to make sure it was fully resetted. Then try and reboot at defualts.
My set up was a ASUS Deluxe with a 280gtx, also is your hardrive been reinstalled with a fresh os?
Make sure your HDD is blank ie reformatted
connect the following......cpu+hsf, make sure its seated well.
one stick of ram in the proper one stick of ram slot according to your MB manufacturer.
your GPU and appropiate pci-e power connector
no hdd
no dvd.....but.....put a power connector from the PSU to the dvd drive.
PC power and cooling units sometimes require a 5v draw before they will stay powered on.
I have had what you describe when forgetting to do just that.....in other words, brief power ups then nothing.
