New system July-ish build? EyeFinity Help.
flooberjobby
Gaming mostly, media, web browsing. Pretty much everything. But mostly for gaming.
Umm about 2,000-3,000 US dollors. Shipping included
3) Where do you live?
Van Horn TX, Hustisford Wisconsin, Sussex Wisconsin, and El Paso TX. Military currently....
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything pretty much it's a new system.
CPU
RAM
HDD
MOBO
Video card
PSU
Case
CD Drive
Wireless(device) IE usb, pci/pci express card, you get the gist. Just need it.
And possibly a sound card.
Won't be.
6) Will you be overclocking?
Not quite sure. Not all that knowledgable on it. But would like 4ghz cpu system and possibly up the graphics card. But if I do I will post up again so I hopefully don't screw things up.
I plan on doing an EyeFinity setup. Hope fully with HD projectors shopping for some cheap ones, or use 3 23" Acer monitors 2058 x 1152 DVI, VGA, DMI
Jully-Ish supposedly Because thats when I am suppose to get back from deployment. I won't do this till I'm back due to needing to test the parts.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Crossfire, RAID, USB 3.0, SATA III (6GB/S), and wireless(optional if I can get an add in)
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Windows 7 Ultimate 64 bit
By answering these questions you help us help you build a PC that's of better quality, better performing, cheaper or all of the above.
The rundown of what I have so far for my system build up of what I am looking at and have found/selected. If there are any issues with anything I have found or selected let me know please.
I'd like an all AMD system if it won't hinder my performance to much.
What I'm looking for/at for parts.
CPU: Open to suggestions
Dependant on when I am back, but thinking mabye a DP system, quad core, or 6 core.
RAM: Open to suggestions
HDD: Open to suggestions
all SATA 6GB/S, thinking raid SSD for OS install, and raid terrabyte drives for programs
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
MOBO: Open to suggestions
Video card: Open to suggestions
Looking at dual 5990s(aka 5970 with 4 gig and 850hz core with 4.8 memory) In crossfireX. Or a better solution from ATi if applicable at purchase.
PSU: Open to suggestions, Modular, future proof
Ultra 1600Watt Modular: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4558882&sku=U12-40500
Cases: Open to suggestions, future proof, water coolable, ect, ect
Corsair 800D: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001
Lian Li PC-343B Modular Cube Case - Black
http://www.xoxide.com/lian-li-pc-343b-case.html
CD Drive: Open to suggestions, looking for Blue ray burner/player
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129051
Cooling: Open to suggestions, for CPU, RAM, NB, Case, GPU, all cooling options available that are pliable for 24/7 use. Like it to be quiet, but thats not allways an option when your wanting everything cool, fast(overclocked), and reliable.
Display: Open to suggestions
3x 1920x1080 Projectors, prefered, no bezels, or really screen obstruction
3x 2048x1152 or higher resolution monitors. Size I don't care about. Just the resolution and quality. It cannot ghost, I plan on getting back into competitive gaming really soon.
Monitor(s) looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009173
I plan on keeping this system for a long while.
Umm... I'm not sure if I missed anything but I'll keep adding/edditing and changing things as we go.
Once a conclusion has been made and purchased, I'll post a build threatd, with video and such.
Thank you all for your help ahead of time it is greatly apreciated. Kinda hard to stay up with everything while deployed.
This is way too early for a build list. Revisit this thread around mid-June or two weeks before you plan on ordering everything, whichever comes later.
Not quite. I can pick out a bunch of stuff for it right now.
And still discuss the pros and cons for what I'd like and am looking for.
You can pick out that stuff now but that doesn't mean that those parts will still be recommended or even worth buying in July. In the next 4 months, virtually every part we recommend today will either be outdated, outperformed, overpriced, or out of stock.
Yes we can discuss the pros and cons for what you'd like and are looking for but that would only apply to parts you're buying within a month from now.
So I concur with Tiraides: It's too early to start planning a build. Two months at most but that's still cutting it close.
Also are monitors part of that $3000 budget?
I said it was too early because new products will arrive and lots of price changes and/or specials will occur between now and June-July when you order. The real "hard part" for this build will be picking out the monitor(s) you want since everyone has a different notion of what makes a "perfect" monitor when there really isn't one.
Ya the monitors are part of the budget.
But I have about 500 or so dollor leeway on going over the budget so far. I'll have to see though offically when I get back.
