New System Build Sporadic Reboot
Current System:
MB: Gigabyte GA-EP45T-UD3P V1.0
Processor: Intel Quad Core2 Q9400 2.66GHz
RAM: Corsair 2GB DDR3 1600 (x2)
HD: Seagate Barracuda ST3500320AS 500GB 7200RPM SATA (x6)
Video: Gigabyte GV-N98XPZL-1GH GeForce 9800 GTX+
Power Supply: Seasonic M12D SS-850 850W
OS: None, yet
Not my first System build, but I'm more of a hobbyist than a tweaker. I'm really building this one for work, and I'd like to get 3 RAID arrays set up. I set everything up, turned the unit on for the first time, I went into BIOS and did my set-up in there, only changing things minimally: I set boot order, I set the SATA mode to RAID, and set the outboard SATA control mode to RAID. I monitored the PC hardware for a about 15 minutes using the Health section of the BIOS, confirmed stability, I then saved CMOS to BIOS, and exited saving the changes. Computer rebooted, giving me a single beep indicating that everything is posting fine, and detected all 6 SATA drives appropriately. I did the CTRL+I to configure arrays, and successfully configured 3 separate RAID Arrays. I exited, rebooted again, and finally got to a point where I was installing the OS. Before I could get the RAID drivers installed using the f6 method, I the computer shut down, and re-started. When it went through the boot sequence this time it found that the device connected to RAID port 4 was No Device Detected, and registered my RAID array as "Degraded". As I was attempting to discover the source of this, it would randomly shut down and reboot itself. Finally I manually shut the system down, and re-started it. It then correctly detected my missing HD, but listed it in the RAID array listing as "Rebuild". Thinking it may be a HD malfunction, I disconnected that Hard-Drive that was giving me problems, and it does seem to boot faster. I do think there's a problem with that drive, but the primary problem of sporadic rebooting seems to persist. I turned it on this morning and it ran for 15-20 minutes, reset itself, then before it was through the post sequence, it rebooted itself again, and now has been running for about an hour just in BIOS. I've been monitoring Temperature and voltage, both of which have remained constant.
I started working on it, installing OS, and it shut down again, at about 1 Hr. 25 Minutes of runtime, all temps and voltages seem constant. It shut-down during HD format, now HD's are recognized within their RAID configurations, but the windows setup will not recognize that there are drives installed.
I'm a little lost on this one. I'm not even sure what could be causing the problem at this point. Any suggestions?
sounds like the raid controllers messed up.. or it needs a bios update..
Updated to the f6 BIOS, which is the latest for this MB, also the problem was occurring before I had installed the RAID controllers. I've since reduced my drives down to just two. I'm going through the tests on the Ultimate Boot disc trying to narrow stuff down, but I can't find anything that's repeatable. This is really frustrating, and any suggestions or help would be appreciated.
Download Memtest86+ v2.11 or whatever the latest version is, unzip it, burn the ISO file to a CD, and then boot from it, just like you would do with the XP/Vista install CD. Let Memtest+ run for at least three hours on each stick of RAM separately as well as test the RAM all together. Go for a full 24 hours if you want to be completely sure that the RAM is not a problem. If you start seeing errors, than your RAM is defective or you have incorrect settings for the RAM.
concerning the incorrect settings, I haven't changed anything on the RAM setup as of yet. I have the everything set to "Optimal Settings". I will check the RAM as you suggest, and respond. Thanks.
My first test of just one stick of RAM ran for at least 4 and a half hours that I monitored. It had 14 pass' and no errors accumulated at that time. I let it run overnight, and apparently it reset itself at some point during the night, as when I checked it in the morning, it read only 2 Walltime hours on the test cyce, and 6 pass', no errors. I'm currently running the same test on only the second stick of RAM to see if the problem occurs there as well.
checked my second stick of RAM in the same fashion. It ran for 7 hrs stable as I monitored it, and then when I checked it again in the AM, It had restarted again during the night. I've still received no errors from the RAM at all, is it safe to dismiss the RAM as the problem? What is my next step in trouble shooting this?
Have you tried building the computer outside your case? I recently built a system with the same motherboard. I had weird reboot issues and RAID issues. I built it outside the case and everything worked fine. I put it back in the case and everything was fine. I must not have had the motherboard properly mounted in the case and it was causing weird electrical issues.
Stupendous, that is a possible solution, one that I may pursue here shortly. I've finished my RAM tests with the following results: I placed a single DDR3 in DIMM1 slot, and ran it overnight. It ran stable for 4 and a half hours that I monitored, but reset itself at some point during the night. It did receive no errors on the Memtest86+ results however. I then Tested the second DDR3 by itself in DIMM3 slot. It ran stable for 8 hours that I monitored, and again reset itself during the night, again receiving no errors. Finally I tested both sticks together in DIMM2 & 4 slots, again the system ran for 9 hours monitored, reset itself during the night. I can definitely say that the resets appear to not be as frequent. When I first turned it on it was about every 15-30 minutes. I think I can safely eliminate the RAM as a possible cause. I've also fully disconnected all hard-drives from the system. It's running the optical drive, two sticks of ram, CPU, GPU, and a floppy drive. Other than pulling the system and running it outside the box, any other suggestions for the next step in trouble-shooting this? Thanks in advance.
Now, I really need some advice. I took the unit down to only the RAM, the CPU, the GPU, and a CD drive. I took it out of the case, and I re-seated everything, including the CPU. I started it up, outside of the case, sitting on it's box. It reset itself within 2 minutes, and after that about every 6 seconds. What do I do with it now?
Update: Oops. I'm retarded. I didn't hook up the power connector for the Video Card. Plugged that in and it stabilized. I'm going to try to run it for a while, monitoring temperatures, and see if I get the same long-term reboot that I have in the past. If I do, I believe that I will attempt to run it without the GPU. Any other troubleshooting advice would be very helpful right now.
Let it run all night again, and it definitely reset itself during the night again. I really don't know what else to troubleshoot at this point. I don't know what else to check, or how to further pinpoint this problem. Please give me some direction.
Strap a fan onto the northbridge of the fan and rerun the tests again.
Try downclocking the RAM down to DDR3 1066 or DDR3 1333 speeds.
I replaced the power supply with the one out of my computer from home. The system has now been running for over 24 hours. I think the Seasonic 850W Power supply is faulty. It's passing every test, and not having any shut-down issues.
