Monolith2013
- Jul 29, 2008
So i'm building a gaming rig for my best friend and i've kinda hit a brick wall as i'm sure most of you will agree...
System needs to have SLI capabilities (unless I can convience him otherwise), the budget is $1500 or less.
I've looked at the 790i boards and w/the DDR3 they're too expensive while the 780i all have overheating issues with the exception of the MSI board (or at least not as pronounced), but then again, i've seen negative reviews on it as well for OC/stability issues.
So, what to do...
These are the boards i'm lookin at within the 780i product line...
Asus Striker II Formula
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131255
Asus P57N-T
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131294
XFX 780i SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813141005
EVGA 780i SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188024
EVGA 780i FTW SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188027
and finally...
MSI P7N Diamond
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130158
From what i've read, i've pretty much narrowed it down to about 3 of these boards... either one of the EVGAs, the XFX or the MSI.
Also, i've selected the Q6600 as a CPU, though i'm wondering if I should go with a 45nm CPU instead of the 65...? Also, would it be better to go witha quad or a dou?
I know I have a pretty heafty decision to make, so any thoughts/comments would be appreciated. Thanks!
So, what to do...
Asus P57N-T
XFX 780i SLI
EVGA 780i SLI
EVGA 780i FTW SLI
and finally...
MSI P7N Diamond
