New setup up and running
Viper87227
I completly redid my WC setup over the weekend. Got a new mobo, added a chipset block, went back to a t-line, and added a fillport. However, I am not so sure I like how it turned out. Temps seem to be normal, but I don't know that I like the layout... I think maybe it could have been done better. So, I got some pics. Next week I will be getting a new video card and switching to a Maze4, so that gives me an opprotunity to re-do anything in the loop. Give me some feedback.
possibly flip your cpu block around so the tubing seems to "flow" better from top to bottom. Id also look to move the T around a bit i think that causes a cluttered look.
what additives are you using? pentosin?
that looks like a heavy pentosin blue solution .. am i correct?
i try not use more than %10 solution and it comes out very light .. which is ok i guess..
mal
You know... I never even thought of that :rolleyes: :D. Good idea, i'll ive it a shot.
Far as the additive, it's not pentosin. It's actually Koolance refill liquid. I use it because the stuff is dirt cheap. $7 for an 8oz package, and I dilute it quite a bit as they premix at 30/70, which is far to much for my tastes. Add a bit of good old H20 and it works out great. I like the deeper blue more than the light blue of pentosin, the temps are absolutly the same, and this is cheaper, so why not ;)
EDIT: As far as the T goes, I think that is really the part that gets to me, but I can't really move it anywhere. Im using a dangerden fillport, and that was the only place I had room for it, so its got to end up in the same spot no matter what, and if I tried to get the T over a bit so that all the hoses arent jumbled up in one spot, it just kinked the hose coming out of the GPU block.
