New rig help ~ $750
Gaming, University work, Music Recording
Budget is $750 Australian
Australia, Sydney
CPU, Case, Gpu, Ram, Hdd, Wireless Card, Power Supply
Keyboard, Mouse
6) Will you be overclocking?
nope
I believe it was 1820 x 1080
Approx 4 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I would like the possibility to have dual monitors going on
No. Need a new copy of windows
Any particular Australian online computer hardware store you'll be buying from?
This is a pre-built model they have. its higher than my preferred price range.
ARC Intel i5 Entry Gaming System 986.96
• Intel Quad Core i5-3470 (3.2GHz) CPU 196.01
• Intel Z68 Chipset MB 99.53
• 8GB DDR3 1333MHz RAM 52.50
• 3.5" 1TB SATA HDD 87.98
• ATI HD-7850 OC 2GB 256-bit DDR5 VGA 292.86
• Dual Layer DVD Writer 25.74
• Thermaltake V4 500W Case 77.44
• Microsoft Windows 7 Home Premium 64bit OEM 89.90
Total (only components): 921.96
Is there possible things I can change to lower the price, without lowering the overall quality too much.
I would love the ability to play most modern games (diablo, starcraft, minecraft) on quite good detail
Unfortunately, that prebuilt is prety crappy on account of the case and PSU: those are pretty shitty parts.
Are Minecraft, D3, and SC2 the only games you'll be playing?
ok thanks for that. Can you suggest a better replacement for cheaper or around the same price?
I like playing wow, guildwars (1 and 2 soon), rift, alot of text based games,
so alot of games hahah....
I will be recording music + using the system for university studies.
All right this is the best you can get for your budget:
$118 - Intel Core i3-2100
$98 - Asus P8H77-M Intel H77 Motherboard
$49 - Kingston KVR1333D3N9K2/8G 2 x 4GB DDR3 1333 RAM
$155 - Asus HD 6850 1GB PCI-E Video Card
$69 - Western Digital WD5000AAKX 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$25 - LG iHAS124-04 DVD Burner
$66 - Antec NEO ECO 520C 520W PSU
$59 - NZXT Source 210 Elite Black ATX Case
$89 - Windows 7 Home Premium SP1 64bit OEM
$21 - TP-Link PCI-E Wireless Adapter
Total: $749
With SC2 and Minecraft, you should be able to get medium to high settings at the least. WoW will probably be around the medium to low range of settings.
Thanks for that!
I'll be ordering the parts in about 4 weeks time, so the price shouldn't vary much I hope.
I'll post here again before hand for any final check ups
