- Apr 7, 2006
Ok so i have my new 16core Nehalem box, but I cant get any VMs to start with more than 8 cores.
Win7 x64
VMPlayer3.0
Win7 x64
VMPlayer3.0
Are you running notfreds or full linux distro in the VMs?
even with dual 8core VM?
I'm not sure of the core limit of the VM3 player, so...
Did you edit the vmware file in a text editor and change the amount of cpu's to 16?
actually i just went thru this earlier today with my 16 core nehelam i decided not to fight with it and just running 2 8 core vms. simple as pie
i properly edited my vmx file and it first told me that 8 cores was the limit, and also after i lowered the cores down to 8 it told me max ram i can allow is 3600mb
im also running server 2008 R2 standard, which is 64bit . my rig has 2x 5520s and 12gb ddr3 1066 registered ecc ram.
Maybe a native install of Linux is the easiest solution?
Im installing 2008 R2
I have the same situation.
I run Server 2008 so no native linux for me either.
Plus, I get so lost using linux.
Just wait a few months for SMP2!!!!!!!
Situation should be over then and us "windows" will be happy again!
Until then, 2 x VM will get you by!
Could you try windows 7 pro? That supports 2 physical processors...
If the disk image was built on a 32 bit box, this is around the limit that the VM can see and is locked there when moved to a 64 bit box.I properly edited my vmx file and it first told me that 8 cores was the limit, and also after i lowered the cores down to 8 it told me max ram i can allow is 3600mb
a few months?
I thought it was going to be out this month?
is there any major benefit to having a single 16 core vm compared to dual 8 cores?
your 32 core box is gonna be a beast ...![]()
Hopefully, we will see true SLI or xFire folding in the next GPU client/core, to allow the massive parallel processing power of our GPUs to be unlocked.90K PPD!!! holy shit
that would be pretty cheap tho, cuz it wouldnt pull much electricity, and the bigest cost is upfront price
I paid 700 for two 295s (30k)
I paid 360 for 3 260's (22k)
I paid 320 for 4 88's (21k)
I paid 620 for 4 GX2s (42k)
Take the 88's out and there is about 90k, for about 1700$ (damn I spend too much on folding)
Then there is PSU's and CPU's, cant forget those...
Im over 2 grand not counting my 88 4 way and I promise I pull more power than his 32 core would..
hmmm.....
i think i should be pushing out about that much now
where could i get a copy of the 64bit vm to run 1x16 -bigadv
btw how do i use HTM.net/fahmon to monitor ppd?
due to my works network and having to authenticate every few hours i have the vm's set to work through NAT,
that would be pretty cheap tho..................
hmmm.....
Try VMWare Workstation.Well its on hold until I can get a 16 core VM going
