New Rig Dilemma
jhwk6957
I need help picking out parts for a build.
Medium Gaming (borderlands 2 on high) light adobe suite cs6 for web design. and yes of course web browsing.
$700 after tax and shipping.
Minneapolis, MN
CPU, RAM, MicroAtx Motherboard, Modular PSU, SSD, storage HDD, CPU cooler, GPU,
Fractal design Define R3 Mini case
6) Will you be overclocking?
Yes, 4ghz
7) What is the max resolution of your monitor? What size is it
single 27" 1920x1080
next two months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
usb 3 and sata 6
Yes, Windows 7 Pro 64bit
Can you narrow down that time frame any further?
Please define medium gaming: which games? How many bells and whistles?
Which Adobe programs are you using?
Borderlands 2 on high with physics on high. I am considering a gtx 660 but any other suggestions would be appreciated. also I use Photoshop, illustrator, Dreamweaver. I am also considering buying one of those Korean IPS panels 2560x1440 at some point for using CS6 but I plan on gaming on the single 1080P monitor
I just got a new job so I would like to wait till at least the first paycheck rolls in next three weeks or so. but I would like to build it asap.
What's the soonest that you can build the PC?
If it's more than a week from now, then I just recommend just coming back when you're 1-2 weeks away from buying the PC and ask for advice then. As a result of doing that, you'll have up-to-date build list without having to constantly recheck for deals or whether or not the part is still a good buy.
Good point. I will just wait till I get paid. Will come back in three weeks
