Core 2 Duo 6750
1900xt 512mb
2x2gb DDR2
DVD burner
5 80mm fans
2 7200 RPM Drives
As of now, I am running the above with a powersupply that was pulled from an emachine and has a maximum output as 288watt.
First of the, the powersupply only has 20 pins, whereas the motherboard has 24pins. Oddly enough, the powersupply does work and so does my system. In fact, I was able to play need for speed prostreet with pretty much maximum graphics.
I did order a Thermaltake 430 watt powersupply, but I'm getting a feeling that I should cancel the order. I mean, this low watt powersupply is doing the job, so would I actually benefit from any increase in maximum wattage?
1900xt 512mb
2x2gb DDR2
DVD burner
5 80mm fans
2 7200 RPM Drives
