Hello, I've decided to build something from ground up this time. Done LOTS of research, but I would really appreciate your comments and suggestions, as there are still things I'm not sure about. Thanks!
And there is a small twist: I'm not buying in the US, so there are some problems with the availability of some parts that I see are often recommended here.
1. Intended usage (most frequent first):
- heavy programming/development/multitasking with often two operating systems running simultaneously (main OS is Linux with Windows in a virtual machine and sometimes some other OSes as well).
- multimedia, video, music
- gaming on a 1920x1200 monitor. I want it to play current games and some upcoming ones like Starcraft 2 and Diablo3 in this resolution.
- graphics editing (2D and 3D), design
In general, I'm a heavy multitasker. The main OS will be Linux and Vista 64bit only for gaming (dual-boot).
The performance of graphics isn't the most important thing. This is not a gaming rig, although it will be used for gaming too. So I would rather welcome a better performance CPU/memory/harddisk-wise than a better GPU.
2. Budget:
Not very tight. Hard to express in dollars, but something around what you see below in parts. I can throw in even $500 or $1000 more, but only if I feel it'd be worth it. I don't want to cut corners, I want to be happy with my build.
Edit: I'm buying in Poland, prices here are higher than in the US. But I'll give you an estimate in US prices from Newegg:
The parts below are around ~$1300 in US prices. I'd say raising it to up to $1600 or heck, even $1800 would still be ok, as long as it makes good sense.
3. Remarks:
There are two parts to this build. The "staying for longer part" and the "to be replaced sooner than later". I will most probably be switching to Nehalem in 1-1.5 years or so, so I will be replacing CPU, MB and RAM (getting DDR3).
But I want to make an investment in things like case, PSU and other stuff that would last years
My general bias is towards quality rather than price, but I like good performance/price ratios, I don't like burning money needlessly.
I won't be starting with OC right away, but I guess some light OCing later won't hurt. Not to push the limits, just to improve performance while staying safe. I'm not planning water cooling.
Edit: after more and more reading, I see getting a Q6600 and OCing it to around 3GHz should be easy and safe. If so, I might be willing to do just that...
What I already have:
- LG-245WP 24'' LCD monitor
My current plans:
Asus P5Q-E
I like Asus, but I don't really need Premium/Deluxe boards. Besides obvious things like performance/stability etc., I'd like:
- the board to manage my chassis fans as much as possible (although I don't think I can get more than 3 chassis fan connectors)
- a decent number of SATA ports (6 is fine though) and possibly an eSATA port (although not that important)
- I don't really need the onboard audio nor plan to Crossfire
- I'm a Linux user so I won't be able to use Asus software for managing OCing, fans, temperatures etc.
Intel Core2 Duo E8400 (or 8500)
I might change to quad, but between 2 more cores and higher frequency, I rather choose the latter. It's a hard choice really... I guess I could do some safe OC on air cooling though...
Edit: starting to consider a Q6600 OCed to around 3GHz... Should be safe? I really want to it play safe!
CPU cooling
This is a problem... I can't get Xigmatek here... Any way to get something decent for under $50 (with light OCing in mind)?
DDR2 2x2048MB PC-800 Mushkin XP CL 4 4-4-12
This is difficult. First thing is, I see many people here recommend G.Skill but they are not available where I live. Second, maybe I should get PC-1000 ones? Don't really see a point though...
I was also considering OCZ 800 4-4-4-12.
I'd like to choose from among Corsair, GeIL, Mushkin, OCZ, PDP...
Asus Radeon 4870 512MB
I was considering 260 too, but I'll trust AMD with their new Linux compatibility this time. Any comments on the brand? I also have Gigabyte, Microstar, Palit, PowerColor and Sapphire available...
Asus Xonar DX
For good quality in music and movies.
Samsung SpinPoint F1 640 GB (ATA/300, 16MB, 7200, NCQ) HD642JJ
I want the best performance from the main hard disk. For storage I'll have other disks so the capacity is not that important. I was (and still am actually) considering the VelociRaptor... If it only was a bit cheaper though...
Sony / NEC (Optiarc) DVD+/-RW AD-7201S LightScribe
Subject to change, maybe for an LG?
And last but not least, case and PSU. I want them to stay with me for the next 8-10 years and I want them to be good.
Corsair CMPSU-750TXEU - 750W
PSU is easy. I want it to last and the price looks good compared to weaker ones.
But the case is more problematic.
- I'm absolutely anal about the layout inside my case, temperatures and airflow. I like when a case is well-designed. And prefer not having to use tools but it's not that important.
- I also want easy access to things, like be able to easily remove/add disks. I often change things.
- I like having many disks, but probably only 1 optical drive.
- I don't mind noise during peak usage, although I'd like it to get quiet when not used. And getting that to work automatically would be nice.
- I want a good looking case, although rather subdued than flashy. Some LEDs and windows are ok though.
I'm not completely convinced yet if I want to spend too much money on the case. But I want a good-quality, spacious, comfortable to work inside, well designed case. Looks go second. I'm open to suggestions, even more expensive ones (but reasonably).
So my idea was:
To get a CoolerMaster RC-690 and just stuff it with more fans. Something like 2 front intakes, 1-2 intakes on the side, 1 back outflow and 2 top outflow, maybe another one on the bottom. Then, connect 3 of them to the motherboard (probably the one in the back and two on the top, as they are near the CPU) for automatic management. Finally, get a 5.25'' panel/controller and connect the rest to it. Any comments on this?
What I like about the 690 is how well it's though-out, its looks, not having to use tools to install stuff, easy access to disks, cable management, vibration dampening. My only worry is probably the airflow.
Another idea was to get the NZXT Tempest and have the fans already there... But the organization inside isn't as good...
Well, I guess this is it. Thank you for reading and I hope for some advice!
2. Budget:
3. Remarks:
My current plans:
Asus P5Q-E
CPU cooling
Asus Xonar DX
So my idea was:
