New PC problems
fsh42na
:confused:I recently built a new pc for my sis-in-law using the following:
Gigabyte P35 DQ6 v1.0 mobo
E6600 C2D cpu (Stock)
4x1gb Adata DDR2 PC6400 (stock - Memtested all 4 sticks, 2 at a time)
EVGA 7600GT video card
2x 300 gb Seagate SATA drives (non-raid)
Samsung and Phillips SATA DVD burners
onboard sound
Corsair VX550 power supply
XP pro sp2 (slipstreamed)
Seagate Pro 500gb external drive (I think she has this plugged all the time)
The problem that she is reporting is that the computer freezes for no apparent reason at times. The only thing she can do is to hit the reset button.
I'm suspecting that the board (1) doesn't like the 4x1gb configuration (2) needs me to bump the MCH voltage (have to check on that cuz I thought I already did) (3) something is getting too hot.
I'm tempted to just swap out the memory for some Adata 2x2gb DDR2 PC6400 that I have lying around. I'm hoping that the XP install is borked. She's had the pc for about a month and I'm worried that the resets have led to some OS instability.
Thanks in advance for your thoughts and suggestions. Have a great day!
You could try running with just 2 sticks of RAM. 2GB should be plenty anyways.
thanks for the fast responses:)
do any of you think the External USB drive could have any connection to this problem?
Should I do an XP repair after I sort out this likely memory issue?
Thanks again
