New PC is almost ready to rock!
Jedimoto
I just finshed installing my new PNY 6800GT and getting everything connected and tidied up. I turned it on and everything seemed good to go. I went into the Bios and checked out the hardware and temps and such and everything looked good. this is my first build so I'm very excited about it all. I have one question about my Sata Hard drive (Maxtor), but I'll post that in the right forum. But I do have another question...
Now that everything seemed to post, and I changed the boot priority so that I can boot form the CDROM tomorrow when I buy XP, is there anything I need to pay extra attention to? From what I've read, the hard part's done, but I want to be sure I'm not missing anything. Thanks for any help...
AMD A64 3400+ CG Clawhammer
Thermalright XP-120 w/Panaflo M1 120mm
DFI Lanparty UT II nF3 250
Enermax Noisetaker 550
Maxtor Ultra SATA 120Gig
Plextor 7A12 DVDR/W
PNY GeForce 6800GT
Sound Blaster Audigy 2 ZS
That's the rig. I'm really proud of it, and can't wait to get it fired up tomorrow.
Looking good man, long as you have everything set right in the BIOS. If you have any problems tomorrow fire away.
Make sure you have a floppy drive hooked up so you can load the SATA drivers when you're prompted for them.
Buckus has a good point there. You will probably need to hit F6 when windows setup prompts you for third-party scsi or raid drivers and load the sata drivers from a floppy. I've seen some configurations require this and others not require it. I think it's a matter of your BIOS and your drive mostly.
Hmmm, ok.
Do I just use the drivers that came with my SATA drive, or download new ones form the Maxtor website and put 'em on disk?
I think you should used the SATA drivers that came with your motherboard, as the controller is on your MB. Copy them from the driver disc over to a floppy and go for it, remembering to press F6 as soon as you see the prompt at the bottom of the Windows install screen.
Yep, you motherboard might have come with a floppy disk for this. Or the CD might have a utility to write a floppy.
From your manual on page 43:
Install the NVRAID driver by using the provided “nVRAID
Driver” floppy diskette. The driver must be installed if you are in
the process of installing Windows® XP or Windows® 2000 on
RAID configured Serial ATA drives.
Once in a while it pays to read the manual....once in a while :D
Ok, I see the confusion here.
I do NOT have a RAID on my PC. Only one single SATA hard drive. Do I Still need to install this disk? I was under the impression that the NVRIAD driver only pertained to RAID.
Once in a while, it pays to read the post... once in a while. :p :D
You don't have to worry about installing any drivers to run a single SATA drive. I know I didn't. I have a similar setup.
You will still need the drivers or maybe not. Glad I could help. LOL! :D :D
Hey, thanks, Met-Al.
You did help. lol. You made me go back and re-read my Manuals. :D
Thanks for the help and encouragement, everybody. :)
Windows XP (unless the added them in SP2) does NOT have the drivers for SATA drives. You will need a disk in that case, and you will have to press F6 in the windows setup to load the drivers. This may have changed with SP2 but there is a good chance that you will need the drivers.
You don't even need to load up drivers if you're going to be using a single SATA hard drive. You only load them up if you're using RAID or something. I installed my Windows XP Pro (no sp1 and no sp2) without needing to load any drivers.
I think that would be the case since the SATA controller is on the chipset instead of on the PCI bus with a addon chip like a Silicon Image controller.
Bought XP Home and installed it yesterday. Everything seemed to work okay, except for Splinter Cell, which came with the Sound Blaster. I installed it and then when executing the program to play it, it just crashed, three times, all right at the beginning with the same error message. The readme file says that the game shouldn't be installed with a CDR/W drive as the game is not compatible with them, but that doesn't make any sense does it? Who makes a game that isn't compatible with CDR/W drives? Plus, all the files seemed to be on the hard drive. I mean, the game won't play with a CDR/W? weird. Guess I'll check out the Splinter Cell home Page and try and figure out what that's all about.
The only thing I can see wrong with my new PC is that in the Device Manager, there is a device with the big yellow question mark on it. All it says is that it's a multimedia device?. The only drivers (or CD's that came with hardware) I have not installed are the ones that came with my Hard Drive (the single SATA drive) Could that be the multimedia device? I don't think it is, but I AM new at this, so anything is possible.
I did NOT install any drivers other than the ones that came on the DFI Mobo CD. But those should have taken care of any SATA drive, right?
Man, I'm confused right now. I'm at work so I can't mess with it until 4pm or so, but I'm gonna try and get that damn question mark out of my devise manager as soon as I get home.
As for the game not working with CD-RW drives probably has to do with the copy protection the games CD uses such as Safedisc or whatever it uses.
You could try to patch the game with a No-CD crack to bypass the copy protection. Can't tell you where to find that here since it is against the rules because of all the warez.
As for the device manger it could be the motherboards onboard audio that your not using since you have a soundblaster. If your system is working properly, I wouldn't worry about it too much, but it would be better to fix it of course.
Try going into your BIOS and make sure you have the motherboards onboard audio turned off.
Some systems you need to load drivers to use a single SATA drive. I know my system I had to do that.
I think the nForce drivers from nVidia take care of that.
DId you download the newest ones from nVidia or did you just use the ones on the CD from DFI. There is a chance that there are newer ones than what is on the CD.
EDIT: Actually read your above post :D
I would go to nVidia.com and download the latest nForce drivers and install them. Read the instructions on installing them. I can't remember if it is proper to install them over previous ones. I install them over previous ones, but that is just me and this is on a nForce 2 board.
But this shouldn't have anything to do with the device manager problem your having since it says it's a multimedia device. But who knows...give it a shot.
Thanks, I'll go to the nvidia site and check out new drivers when I get home.
Man, work is taking forever now that I only want to go home and play on my new computer. :D
I think it might all come down to that then... every install ive done was an add-on controller that needed drivers. If its on the chipset then I suppose it might be a different story.
Update your chipset drivers. Go to www.nvidia.com. Click on Download Drivers at the top.
Platform / nForce Drivers > Unified Driver > Windows XP
And download the 5.10 drivers.
It should be ok to install them over the current ones you have. I learned the hard way that if you remove previous chipset drivers, Windows won't load. You'll get a BSOD everytime when trying to boot. That made me have to reinstall Windows.
I'm curious to know. What temps are you getting @ load with that heatsink? I was thinking of getting the XP-90 but I might reconsider. Was the installation hard with that XP-120?
Yep, same here.
Well, haven't had a lot of time to test it out. Busy with getting all the drivers updated and what-not in the small, fleeting spaces of time I have between work and sleep. ;)
The Idle temps are being read by the Mobo as 39-40c. Under load.... I dunno. HEck, I'm not even sure how to check under load. from what I hear the XP-90 is damn near as good. As far as installation went, piece of cake. You just gotta believe them when they say to FIRMLY push on the clips when engaging them with the collar surrounding the CPU. Fits nice, though. It clears everything on my Mobo, but the four-pin 12v power connection was a little hard to get to because of the sheer size of the heatsink. I got it in there, though. So far I'm really impressed with Termalright's quality.
Truly, the hardest thing was lapping the base of the XP-120 to get to the copper finish and shining it right up. Took a couple of hours, broken up in about four sessions. :D
