New PC/HTPC build
Cr@zZy
Hello Everyone,
I am looking to build a new PC that I will use in my living room as a media center PC running WMC most of the time. I would like a little more horsepower for surfing the web and the possibility of in the future it being used for something more. Lower power use is important to me because it could be on a lot.
Here is what I have come up with so far. I am on the fence as to whether or not I want to jump up to the more power hungry i5. Shown below is the low wattage i3. Please let me know what you think. Is the H97 appropriate for my needs? Would a H81 be sufficient?
HTPC, web browsing, office
~$600-700+ not including shipping/tax
U.S., St. Paul, MN
CPU, Motherboard (integrate graphics), RAM, PSU, SSD, HHD, case,
none
6) Will you be overclocking?
no
1920x1200... would like to be able to do 4K TV output with an upgraded graphics card in the future
ASAP... like tonight
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
HDMI out, USB 3.0, onboard vid
I already have a copy of windows 8.1 x64
Silverstone Tek Micro-ATX Mini-DTX, Mini-ITX Mid Tower Computer Case with Aluminum Front Panel and Steel Body TJ08B-E - Black
$99.99
ASRock ATX DDR3 1333 LGA 1150 Motherboards H97M PRO4
$78.99
Intel I3-4130T 2.90 3 LGA 1150 Processor BX80646I34130T
$127.99
Samsung Electronics 840 EVO-Series 120GB 2.5-Inch SATA III Single Unit Version Internal Solid State Drive MZ-7TE120BW
$79.81
WD Green 2 TB Desktop Hard Drive: 3.5 Inch, SATA III, 64 MB Cache - WD20EZRX
$82.99
Crucial Ballistix Sport 8GB Kit (4GBx2) DDR3 1600 MT/s (PC3-12800) CL9 @1.5V UDIMM 240-Pin Memory BLS2CP4G3D1609DS1S00
$74.22
Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS (CX600)
$62.00
Thank you!
For the usage you've described, A COre i3 is more than enough. However, I would not bother with the COre i3 4130T at all since it doesn't actually save you any power: Its idle power is exactly the same as the Core i3 4130. Its load power usage however is lower than the Core i3 4130 but that's due to the lower clock speed. As such, that 4130T may end up using more or equivalent power as it needs more time to do a certain task. So stick with the Core i3 4130.
Go with this significantly higher quality XFX PSU instead:
$67 - XFX TS Series XFX TS 550W PSU
Thank you for the advice. I think I might bump up to the i3-4360 for $20 more to get a higher clock and improved onboard video.
