New PC Build
Status
Not open for further replies.
iGamiak
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc- Light gaming and video editing.
2) What's your budget? Are tax and shipping included? $1,000. Yes
3) Which country do you live in? If the U.S, please tell us the state and city if possible. U.S. Naples, Florida.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. Motherboard, CPU, Graphics card, RAM, optical drive, Hard drive, windows 7 home premium, monitor, mouse, and keyboard.
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. none.
6) Will you be overclocking? no.
7) What is the max resolution of your monitor? What size is it? I have no monitor.
8) When do you plan on building/buying the PC? 1-2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc. I was thinking about the as rock z77 extreme 4.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? no>
This is my first build and I might not understand some of these terms.
So video editing is the main use for this PC? What exactly is light gaming for you?
What games do you want to play? This video card may be overkill.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
Memory: Crucial Ballistix sport 16GB (2 x 8GB) DDR3-1600 Memory ($79.99 @ Newegg)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($89.93 @ Amazon)
Video Card: Sapphire Radeon HD 7850 2GB Video Card ($195.98 @ Newegg)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: PC Power & Cooling Silencer MK III 500W 80 PLUS Bronze Certified ATX12V Power Supply ($55.71 @ NCIX US)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($15.99 @ Newegg)
Monitor: Asus VH236H 23.0" Monitor ($139.99 @ NCIX US)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($91.99 @ Amazon)
Total: $939.55
(Prices include shipping, taxes, and discounts when available.)
Either way, I wouldn't recommend the Extreme4, because unlike ASRock's previous generation, it has substandard MOSFETs.
The graphics card requirement would also vary depending on the resolution you will be playing games at.
I am looking for a case that has usb 3.0 and 2.0.
You do realize that you can plug a USB2 device into a USB3 port, right?
For cheap keyboards, just get the cheapest Microsoft or Logitech keyboard.
I will be playing alot of different games and i want to run them on above average settings. I want to do basic video editing of gameplay. So i will be using this pc for gaming mostly.
In that case, the CPU that Mercuri chose should do the job.
As for the case, the Azza Hurricane really isn't that good of a choice since there are higher quality, roomier, or better cable management having cases out there for around and less than that price range. Not to mention that it's out of your budget. J Macker is correct that USB 3.0 is backwards compatible with USB 2.0
I recommend these cases since they're still in your budget:
$75 - Corsair Carbide Series 300R ATX Case
$80 - Corsair Carbide Series 400R ATX Case
$100 - Antec 1100 ATX Case
Speaking of budget, that PC Power & Cooling Silencer MK III 500W is no longer available at that $55 price point. So I recommend replacing the PSU with this:
$57 - Antec NEO ECO 520C 520W PSU
Don't bother with that Crucial RAM either: It went up by $10 and therefore no longer worth getting. I recommend this Corsair set instead:
$70 - Corsair CMX16GX3M2A1333C9 2 x 8GB DDR3 1333 RAM
No, still not what im looking for. I want a sleek black finish with blue LEDs.
Well keep posting cases here until we tell you which one is good to buy. So far, both of the cases you've selected aren't good.
Good choice. A tad outdated due to the lack of USB 3.0 but still a good case. Better order that case today if you want to take advantage of the $20 off promo code they're advertising.
I want a case that incorporates LEDs that are blue and isnt heavy and massive
blue LEDs, not heavy & massive (doesn't matter if sleek)
then that brings us back to my original suggestion of the Rosewill challenger:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147060
(I don't think it's necessary to spend $100 on a case when a $40-$60 case gets almost the same result)
I own one of these and it's very nice:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208036
this one also looks good and much cheaper than $100:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208045
It appears that we have no real good idea what "looks good" to you so please do your own research on good looking, but acceptably functional cases. Check out these Review Websites that are reputable and offer a better insight into which cases are good and what they look like. You will be able to easily browse through cases and then when you decide what you want, you can tell us and we may be able to help you find a vendor and good price:
http://www.overclock.net/products/category/computer-cases
http://www.tweaktown.com/cat/cases_cooling_and_power_supplies/index.html
http://www.legitreviews.com/articles/case/
http://www.hardwaresecrets.com/page/case
http://pro-clockers.com/cases.html
http://www.madshrimps.be/articles/category/14#axzz2B7XNuLNo
http://www.pureoverclock.com/review_hardware/cases-psu/
CPU Intel Core i5-3470 3.2GHz Quad-Core $191.97
Motherboard ASRock H77M Micro ATX LGA1155 $64.99
Memory G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 $69.99
Storage Western Digital Caviar Black 1TB 3.5" 7200RPM $89.93
Video Card Sapphire Radeon HD 7850 2GB $190.98
Case NZXT Phantom 410 (Black) ATX Mid Tower $99.99
Power Supply PC Power & Cooling 500W ATX12V $71.74
Optical Drive Lite-On iHAS124-04 DVD/CD Writer $15.99
Monitor Asus VH236H 23.0" $139.99
Operating System Microsoft Windows 7 Home Premium SP1 (64-bit) $91.99
Keyboard Microsoft ANB-00001 $10.98
Mouse Razer ABYSSUS Wired Optical $31.98
Total: $1070.52
Its a little over the budget but im happy with it. Any problems with it?
Status
