New PC Build
sjw7
Hi All
I am looking to upgrade my five year old PC to something that will do me for another five years. I have already purchased a new graphics card which is in use in my current PC so i only need a CPU, Motherboard, SSD and Memory. I would like to reuse my case as while its pretty old its big and i would rather spend the money on things that make it go faster. The PSU isnt the greatest in the world and i would rather not buy a new one but if i need to i will.
Current setup is as follows
Intel E6400 (2.13ghz)
4GB OCZ 6400 RAM
Gigabyte 965-DS3 Mainboard
Sapphire Radeon 6870 1GB
HIGHPOWER 500W ATX Power Supply Unit
Antec PC Performance Case
One of my primary requirements is I want to be able to use the Intel Quick Sync to encode video while still making use of the Radeon graphics card.
I am interested in recommendations on a Mainboard along with 8GB of memory as well as an SSD. The SSD will be for OS and primary applications while i have some older 300GB SATA drives for putting generic stuff on so 60 or 120GB if the jump in price isnt too high would be fine.
I am after good performance rather than loads of features that will be of limited benefit.
Gaming (Wow, Eve Online, Diablo 3)
Video encoding
General office type work
£500 including VAT and shipping.
UK
CPU - i7 3770k
HDD - 60 or 120gb SSD but not sure which model
Motherboard - not sure which one to get
Memory - 8GB but dont know which one to buy
I have the following which i intend to reuse
Highpower 500W ATX Power Supply Unit
6) Will you be overclocking?
Not at first but I want the option in the future.
1920x1200 main monitor 1280x1024 for my second monitor
Going to buy the parts at the end of May/beginning of June
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I do want 6Gb/s SATA but I dont need to run more than one graphics card or have onboard RAID functionality.
Yes using Windows 7 64bit at the moment which can be transfered to this machine.
You're gonna need a new PSU no matter what. Grab the Antec Neo Eco 520W, Antec High Current Gamer 520W, or Corsair TX650 V2.
SSD wise, go for the Crucial M4, Plextor m3, Intel 520, and Samsung 830 series SSDs.
RAM wise, make sure that the RAM is rated at 1.5V and is at DDR3 1333 or DDR3 1600 speeds. CAS 9 will be fine. That's really all you need to make sure that the RAM you're buying is a good choice.
Motherboard wise, you might be fine with the MSI Z77A-G45 or Gigabyte GA-Z77X-D3H
The new Crucial M4 64/128/256GB SSDs have just gone under $1 per 1GB. Newegg has em - Good time to buy!
Thanks for the replies. Exactly the kind of thing I was looking for.
I have picked the following (all prices include VAT) to go with the i7-3770K
Antec 520W High Current Gamer PSU - £60.74
Crucial 128GB M4 SSD - £90.20
Corsair Vengence 8GB (2x4GB) DDR3 1600mhz CL9 1.5V Non-ECC Unbuffered - £38.76
Gigabyte GA-Z77-D3H mainboard - £79.99
I thought the GA-Z77-D3H rather than the GA-Z77X-D3H as i couldnt see much difference except for SLI support on the latter which I cant see myself needing.
Case wise i am stumped as things seem to have moved on quite a bit since i last purchased one which was a good ten years ago. Thinking of £50-100 budget for this bit of it.
cheers
Simon
I wouldn't have gone with that RAM since the heatsinks are too tall and therefore may interfere with 3rd party HSF needed for overclocking. I would have spent the extra cash for the low profile model:
http://www.ebuyer.com/274035-corsai...ile-vengeance-memory-kit-cl9-cml8gx3m2a1600c9
Case wise, I recommend the following:
$76 - Corsair Carbide Series 300R ATX Case
$100 - Corsair Carbide Series 400R ATX Case
$100 - Antec 1100 ATX Case
$115 - Corsair Carbide Series 500R ATX Case
$120 - Fractal Design Define R3 Arctic White ATX Case
$120 - Fractal Design Define R3 Silver Arrow ATX Case
$125 - Fractal Design Define R3 Black Pearl ATX Case
$120 - Lian Li PC-9F ATX Case
$120 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$130 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$130 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$140 - Antec P280 ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$140 - Corsair Obsidian Series 550D ATX Case
$144 - Silverstone RV03B-WA ATX case
$150 - Silverstone TJ04B-EW ATX Case
$160 - Corsair Graphite Series 600TM ATX Case
$160 - Silverstone RV02B-W ATX case
$164 - Corsair Special Edition White Graphite Series 600T ATX Case
$178 - Silverstone RV02B-EW ATX case
$162 - Corsair Obsidian Series 650D ATX Case
$220 - Silverstone FT02S-W ATX Case
$230 - Silverstone FT02B ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
