http://hardforum.com/showthread.php?t=1718810
Hello
I've build a pc with a friend, all the parts are in the link above/ below. We have the pc put together (guess we should have tested on the bench before putting it in the case) and now it starts up (we can hear the hdd for a sec then the cpu fan starts up, acts like it going to post, then stops, and repeats after a couple of seconds. We reseated the ram / video card, checked the connections, and same thing.
Intel Core i5-3470 Ivy Bridge 3.2GHz (3.6GHz Turbo Boost) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637i53470
MSI Z77A-G41 LGA 1155 Intel Z77 HDMI SATA 6Gb/s ...
G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBNT
Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
NZXT Source 210 -Inches ELITE-Inches Midtower Case with 3.0 USB - White
Hello
