Would just like a little input as to the parts being used, and/or if here any better alternatives.
Q6600
eVGA 8800gtx
corsair xms2 4gb DDR2 800
MSI P6N SLI Platinum
XION Supernova 600w PS
Raptor 150gb, 2x 500gb WDD
X-Fi XtremeGamer 7.1
This is also going to be water-cooled(first time doing it). And would like your input, as I am piecing it together
first thing, is there any cheaper, similar alternatives to this?
Koolance RP-1000BK 1kW Series 5
I really like the looks/temp readout of it, and like the compactness of it. Its just, its $250 and its basically a reservoir and pump.....
What about these waterblock and rad?
Thermaltake Aqua TMG1 120mm Radiator
Zalman ZM-WB4 Gold CPU Water Block
Would just like some basic input, will be running this on vista premium/Ultimate. Used mainly for gaming. Not gonna try and push any limits on overclocking, but would like to push it as far as i can, safely with what i have.
also, is nvidia planning on releasing any new cards in the next 3 months? Just want to see if I should purchase the step up program with the 8800gtx.
Q6600
eVGA 8800gtx
