a.) Gaming - All
b.) Video & Photo editing
c.) Most other things
under $1500 (for some of the parts) - Under $1000 leaves more room for additional monitors, etc. for the future so value is always taken into account on a part by part basis.
3) Where do you live?
USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, GPU, MOBO, Memory & possibly (PSU, HDDs)
To be reused:
a.) Cooler Master COSMOS case
b.) Logitech Keyboard/G9x mouse
c.) Dell 3007WFP LCD
d.) Lite-On DVD writer
May or may not be reused depending on what the community here thinks:
a.) 2x500GB SATAII WD HDD's
b.) 620W HX Corsair Modular PSU
Would not be reused:
a.) memory - ddr2
b.) cpu (e6750)
c.) gpu 8800gt
d.) mobo Gigabyte p95
6) Will you be overclocking?
Not planning on it
30" Dell 3007 WFP LCD 2560x1600 (may buy two more of these in the future, or two additional monitors to sit on each site)
This week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
RAID 0
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, Windows 7 Ultimate 64bit
Basically, I'm looking to reuse my case, gut it and replace the internal components, primarily mobo, proc, video card, memory and more than likely (PSU + HDD's) and am looking for the best value / optimal lineup for these combined parts. I play a fair amount of games and do a lot of intensive tasks that stress various parts. The 8800GT can't really handle 2560x1600 very well so I'd like to get a GPU that's capable of doing that at least with decent settings for most games. I would lean towards having more memory as well, my current 4GB seems like it's getting capped pretty frequently. In reading a bit, I'm guessing this build would consist of an i7, X58, 6 or 12GB DDR3, and some ATI or NVIDIA variant. Note that although I'm fine upgrading HDDs for performance reasons, I don't really need them for space. With 50mbit FiOS it hardly makes sense to store huge libraries of data, and right now I've got about 1.5TB unused between the RAID0 and the external 1.5TB drive. I'm not sure what's out there since I last checked so I'm doing a gut check here to see what you all might recommend. Thanks in advance for all of your help.
a.) Gaming - All
USA
To be reused:
a.) memory - ddr2
b.) cpu (e6750)
c.) gpu 8800gt
Not planning on it
This week
RAID 0
