- Nov 7, 2008
Yup....So still crap drivers. Thanks.
I agree, in the past I could update my drivers really without doing any research and wouldn't have any problems. Now, it seems like every driver update introduces some new problem.The last three drivers will make Shadow of the Tomb Raider crash if using ray tracing on ultra. Nvidia have known about this for a while but no mention of when it will be fixed.
I guess all drivers are flawless if you don't happen to play any of the games or use any of the configurations that have known issues...Sorry to those suffering issues. 572.60 installed on my 3070 mobile working flawlessly though.
Does your PC wake up the monitor?Have been running the 572.60 drivers with my 4090 without issues including Black Ops 6 with frame gen enabled for the heck of it. The only issue I had with the previous driver was on boot it would sometimes hang on a black screen, but that issue has gone away.
Yes.Does your PC wake up the monitor?
OK, I tried re-installing the 572.60 drivers to see if they were the cause of my explorer.exe issues, and although I haven't had that occur again I've had two incidents where I was working at something on my desk and my monitor goes into sleep mode, and I can hear my fans ramp up to 100% and once my computer rebooted, and the other time my system recovered from an nvlddmkm error on wake. My system is usually rock solid stable, so these drivers are definitely half baked. Running a 4090 with Windows 10.Ok I thought the new driver was stable. Then came back to the PC and black screen - no wake up monitor. Had to hard reboot. Reinstalling older drivers. Only good thing is DLSS4 looked dope in COD BO6. So not sure if there are other ways to use the DLSS model. Plus VRR flickering is back.
Interesting, I'm on 11 and 0 issues with any of the games I'm currently playing.Running a 4090 with Windows 10.
I'm on Windows 11 as well no issues.Interesting, I'm on 11 and 0 issues with any of the games I'm currently playing.
I am on Win 11 latest version. Issue with black screen happens when you return after a while so if you have a habit of shutting down PC it won’t matter. I never shut down my PC so when I return monitor doesn’t turn on. A few times the driver may reboot and it turns on with an error. For me this is unusable in current form and has been for past 3 releases.Interesting, I'm on 11 and 0 issues with any of the games I'm currently playing.
I wonder, are those of you having issues all on 10 as well?
I'm going to move my usual in-office days around next week and go in on Monday so I can be home on Wednesday March 5 and Thursday March 6. March 5 is the 5070 launch and March 6 is the RX 9070XT and RX 9070 launch. Last time I bought an NV card was December 8, 2020 - RX 6900XT launch day. NV cards were dropping all over the place. I struck out on AMD.com trying to get a 6900XT, but landed a 3090 on BestBuy.com a little while later. I suspect NV likes to shit on AMD's parade. Also if the rumors that NV is engaging in "scarcity marketing" are true the arrival of competitive products may mark the end of their "scarcity marketing" campaign.I always buy day one on launch. This is first time I haven’t managed to get a card already one month later. Probably because I am also not trying hard enough.
That may also be it, I have a screensaver for when I walk away for a bit, usually put PC to sleep while gone and I haven't yet let then screen turn off since driver update. I'll give it a try in a few and report back.I am on Win 11 latest version. Issue with black screen happens when you return after a while so if you have a habit of shutting down PC it won’t matter. I never shut down my PC so when I return monitor doesn’t turn on. A few times the driver may reboot and it turns on with an error. For me this is unusable in current form and has been for past 3 releases.
Add to that VRR flicker on OLED is back - something that was fixed almost 6 months ago.
After a very very long time this is first time I am facing issues that made me never look back at AMD. So if this continues I don’t know what I will do as Nvidia is supposed to be the company that knows how to code drivers.
I've had repeated issues with NV drivers and machines not waking up from sleep over the past couple of decades. It most often happens when I have a recently launched card, but I don't usually upgrade drivers all that often unless I have a recently launched card. Mostly just when I have an issue or get a game that's newer than the drivers I'm running. As a result I've gotten into an environmentally unfriendly habit of disabling automatic sleep mode. Turn off automatic sleep on a new rig, then never get around to turning it on.That may also be it, I have a screensaver for when I walk away for a bit, usually put PC to sleep while gone and I haven't yet let then screen turn off since driver update. I'll give it a try in a few and report back.
Could be the monitor. I've had different levels of success or not with monitor wakeup depending on the specific monitor. Currently with a 4090 and PG32UQX, I have zero issues. However, in the past with other configurations I've sometimes had problems where it didn't wake properly.So I'm back, and it works as it should. Changed settings to turn off monitor after 1 minute. Left for at least 20 minutes. came back and moved the mouse, and both monitors turned on after about 1 second of delay. But working as it should.
I'm stumped about what else could be the differentiating factor.
The hot fix seems to be directed at your issue. Probably wouldn't hurt to give it a try.Apparently there is a hotfix driver. Wondering if I should bother.
I can't even find a 5080 Scalper prices are going down for them on eBay 699 cards listed as I type You have two types of scalpers Individuals and Corporate outlets the store fronts charge unreal prices like on Amazon. I just hope Nvidia is still producing cards not just saying hey here you go Gamerz Nexas review this for us. If there was a news outlet showing the factories producing cards that would be great but we get second hand news. That is one thing Video Cardz doesn't do is show us inside the GPU production process they get leaks from guys with Anime or Indy Car drivers avatars.I always buy day one on launch. This is first time I haven’t managed to get a card already one month later. Probably because I am also not trying hard enough.
Apparently, I can buy a 5090 for a cool 4000$ today. 5080s I have had opportunities to buy at MSRP or near MSRP (like 200$ extra) but I passed on them all the time.I can't even find a 5080 Scalper prices are going down for them on eBay 699 cards listed as I type You have two types of scalpers Individuals and Corporate outlets the store fronts charge unreal prices like on Amazon. I just hope Nvidia is still producing cards not just saying hey here you go Gamerz Nexas review this for us. If there was a news outlet showing the factories producing cards that would be great but we get second hand news. That is one thing Video Cardz doesn't do is show us inside the GPU production process they get leaks from guys with Anime or Indy Car drivers avatars.
I just installed the Hotfix until something comes up again on the Nvidia App.
Win 10 is dead. Nothing in my house but Win 11 and variations of Linux.Interesting, I'm on 11 and 0 issues with any of the games I'm currently playing.
Well, I'm sorry to hear you are still dealing with issues. At this point the only differentiating factor that could be causing these black screen issues may be the monitors or perhaps the system RAM.Win 10 is dead. Nothing in my house but Win 11 and variations of Linux.
I have one box out of three running Nvidia without issues. My 7800x3d box works fine. The 9800x3d box had to be rolled back and the lappy is facing a clean install.
