new mobo - DOA??
synaptical
I just got a new motherboard from newegg, but it won't start. Only the fans and lights come on. I'm kind of new to building computers, how can I tell if it's DOA or I'm doing something wrong??
Please give us a complete list of the hardware you used, it might be easy to find the email or get your online order list and paste it in a post. We can then check for things like memory compatibility with the motherboard etc.
A couple of things to check,
Did you plug in the aux power connector onto the mother board, not the big one, there should be a smaller one also ?
Power it off and remove everyting except the cpu and heatsink, ONE stick of ram and your hard drive and video card. (remove any sound cards, unplug floppy and any other drives , unplug anything you dont absolutlely need for the computer to power up,
Did you hear any beeps at all ?
hey, thanks for replying. i think it might be the 4-pin power connector. i've only built socket A before, and this is A64, so i think that might be it. i'm not at home now so i can't check it until tomorrow, so i'll post back then if it doesn't work. appreciate.
well that could be the problem, but u didnt put it on any carpet? did the light on the mobo come on?
nope, no carpet. it was the 4-pin psu connector. thanks for the pointers, everything's working now. :cool:
