A little bit of gaming, mostly photo editing, and storage. Have a laptop for web browsing etc.
Don't really have one, as if it's more than I want, I will just wait and save up more!
Uh, greater Seattle area.
I will be re-using the case (at first), then the hard drives [I think one is a seagate 500gb and a Seagate 1tb, not sure on exact models.], then also the optical drives, as well as the EvGA GTS-450
6) Will you be overclocking?
No, as I do not know enough about the subject, nor do I really want to risk the hardware.
See below for monitor specs.
Building
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Uh, I don't know? It needs to be fast, and needs to either have a way for me to transfer photos directly off the card (Fastest way) or for me to use the USB connection on my camera to transfer them (Not so fast)
One of the hard drives I plan on reusing has Windows XP on it so I will be using that. HOWEVER, I would like to upgrade to Windows 7 in the near future. That would be after saving up and purchasing Windows 7 and a new hard drive to throw it on.
BUILD COMPONENTS
CPU:http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
CPU COOLER:http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
MOBO:http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
RAM:http://www.newegg.com/Product/Product.aspx?Item=N82E16820231442
PSU:http://www.newegg.com/Product/Product.aspx?Item=N82E16817139031
MONITOR:http://www.newegg.com/Product/Product.aspx?Item=N82E16824236052
PERIPHERALS:http://www.newegg.com/Product/Product.aspx?Item=N82E16823126097
CASE (FUTURE UPGRADE POSSIBLY):http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239
I hope that includes everything I need to include, and is in the right format! Thank you for all/any input!
Building
BUILD COMPONENTS
