New MB and Video card, having problems
EliteFantasy
I am having a problem that I believe is related to the graphics card. I built a P4 2.8 Ghz SFF computer about 3 years ago. It had an AGP ATi graphics card in it. I sold it 2 years later to my sister when I bought a laptop.
Now, the screen would not get a signal sometimes. It got to the point that the computer eventually stopped the start-up beep as well. I had another power supply to check with so I know it was not that. My diagnosis was that a failing video card killed the motherboard.
I ordered an MSI NEO-V P4 board, a new ATX size case, A-Power power supply, and an XFX Nvidia 6200 AGP card. I have everything put together and it seemed to work fine. I tried the original video card and got 8 short beeps no matter how I reseated the card so it was definitely dead. I could not remove the old ATi drivers first because I needed a video card. After it was all up and running I removed everything ATi.
My problem is now that the screen will go blank for a couple seconds and then come back when I do something graphically. I figured out that setting the refresh to 75 Hz was doing it. I changed it to 60 Hz and it will still do it, but less now. It could not display the original screensaver smoothly so I changed it over to an easier one. If I make the screen flicker quickly a few times it will restart and say it recovered from a fatal error. If I leave it on for a long time doing nothing, the screen will go black and then say no signal, and it will not come back. Restarting it says it recovered from a fatal error.
Some thoughts I have are that the card I have is bad, the ATi drivers are still messing with it, or a program (like styleXP) is screwing it up. What can it be and how can I fix this?
Thanks.
I would rather not if I do not have to.
I remembered I had a Raptor sitting around so I disconnected the original HD and then reformatted the Raptor with Vista. I updated to the latest Vista drivers but I am still getting video instability and a BSOD.
I am going to exchange the card for an ATi to see if it is a hardware incompatibility. The last possibility I see is the MB has a bad AGP slot or something.
There's no "hardware incompability".. it's defective hardware. There's no reason that an AGP card and an AGP motherboard should not work together, hence the point of the AGP standard.
I've also never heard of a graphics card killing a motherboard...
You say that as if no one has ever had any problems ever when building a system or upgrading. I exchanged for an ATi 9550 and it works with no issues except that if I try to update the drivers, the system gets stuck in a reboot cycle.
The computer made the start-up beep even when the video card failed and then eventually stopped beeping all together. On board video would not work and another power supply did not make it work again. Maybe it died from movement and many restarts, but it did die.
