I currently have a nickel cpu and GPU block along with a computer radiator - what do you guys recommend for fluid?
In the past, I used to run distilled and silver kill coil in my copper loop, but not sure if I should be going a different route since I'm using nickel blocks now.
tanks!
tanks!
