New Intel build issues.
ShepsCrook
Alright, so I've been in the process to upgrading to an i7 system, and it's proven to be a very tedious process.
First, here's the setup.
i7 920
3x2GB OCZ DDR3 1600 Reaper HPR 7-7-7-24 ram
HD6850
Crucial SATAIII 128GB SSD
Seasonic 620w Modular 80 bronze PSU
X-Fi Platinum
Corsair H50
Herein lies the problems:
(first motherboard) Gigabyte GA-X58-UD3R rev. 2.0
This is an Open Box item from Newegg that would power on, not boot cycle, but would never reach the Bios screen. No beeps, no warnings, nothing.
Tried reseating CPU, memory in the proper slots (per manual, as well as online, also including 1-2 sticks of ram), checked and rechecked all connections.
2nd motherboard: MSI X58 Pro-E
Took multiple tries to get this to post, after it posted, forget trying to move it without having issues. Finallly after getting it to post and in a spot I can deal with, I install Windows 7 Pro 64bit on a horrible resolution 8bit looking screen, and after the reboot, I get "signal out of range" displayed on my screen. After that it just sits there. I of course have rebooted, shut down, reset, let sit for minutes to type this and get no further.
What am I doing wrong? or am I not insane?
This is a picture that shows what the Windows install screen looks like.
stop being a noob!
1.) make sure power suopply is unplugged from 120v wall AC
2.) press power button on front of computer to release capacitor charge
3.) take EVERYTHING out of the chassis you're going to use. Put the motherboard on an anti-static mat, or other non-conductive surface (like the motherboard bag it shipped in)
4.) put on your grounding wrist strap
5.) check your CPU seating in the socket
6.) check that CPU fan is plugged into the proper CPU FAN header on the motherboard, and NOT a system/chassis fan plug. some boards swon't boot unless the CPU fan is where it's supposed to be.
7.) use a known good stick of RAM, just one
8.) Clear CMOS with jumper
9.) disconnect all USB/firewire/FP audio headers
10.) disconnect all but the power switch from board headers
11.) use a PCI video card, or PCI-E card that is known good and functional that DOES NOT require PCI-E power connections (6 or 8pin)
12.) disconnect ALL drives, you don't need them to boot
if that doesn't boot, then it's probably the board... but if you haven't tested the CPU to be functional yet, test that in another system
if it does boot, put RAM in 1 at a time until it's all installed
reconnect USB/Firewire/FP Audio one at a time
reconnect FP headers (reset, power LED, HDD LED, etc) ONE AT A TIME
reconnect drives ONE AT A TIME
put your 6850 back in, and connect PCI-E power to it
also... get a PSU tester, or find someone that has one. Check that your board is not shorting out by having a standoff installed in your motherboard tray area that's making contact with the board where there is no mount point
Well let's see, your 1-12 steps. Did all of them, except for testing with a PCI card. I did test with an alternative PCI-E card that required no added power. HD5450.
I've tested using 1 ram module at a time as stated in my first post,
I've started with bare minimum connected.
I don't have a PSU tester sadly, and noone I know has one.
However, right now I have it running Memtest for a bit to see if there are memory errors.
I will say this, it's very strange that the Windows 7 install looked like an 8bit Windows 95/98 setup. Since Windows uses a very basic VESA driver which should be able to handle making the install look good.
Ok, so it passed the memtest.
I tried a different installer for Windows 7 pro 64bit and still the same thing.
I'm looking into slipstreaming the drivers, but I don't think this is even the issue.
Well, after getting Windows installed, drivers loaded for the video card. The video card still says it's a "Standard Graphics Adapter" so I think there's a chance all of this could point towards the video card I purchased from Nexx on the forums.
Sabregen, why are you calling him a noob? That's a bit....ahem...rude.
you don't know me very well. :D It was a joke, though ;)
sounds like it could be the issue... how did the Radeon fare when you dropped it in (did I miss that part)?
The Radeon is shown above in the picture. And when Windows says "Standard Graphics Adapter" it's talking about the Radeon.
So I'm thinking that it's the card. However, I'm going to try to put the GA-X58-UDR3 V2 in the system again and see if that will work again, AFTER I test the HD5450 card in place of the HD6850 to see if that fixes the graphics issue.
