Gaming, web surfing mostly. The games I play are the iRacing simulator which isn't too system intensive but would like to set up a triple monitor rig in the future as money allows. I also play Civ V with huge custom maps. Those two are my primary games as of now.
$1,000
3) Where do you live?
Hot and dusty SW Oklahoma
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
Motherboard, CPU, graphics, ram, fans and cpu fan/heatsink
5) If reusing any parts, what parts will you be reusing?
PC Power and Cooling 750 watt Silencer
Voodoo Rage pc case (with 2 x 80mm intake fans and 2 x 80mm exhaust fans)
DVD burner
Creative Labs Audigy2 soundcard
Logitec Z5500 5.1 speaker system
Western Digital Caviar Black 750 gig HD.
When I first installed this drive with Windows 7 it made a metallic "ticking" noise so I RMA'd the drive back to newegg.com. The replacement drive did the exact same thing so I just utilized my old Seagate ST3500 350 gig drive and relegated the WD drive for storage. Don't really want to purchase a new hard drive but I will if it's recomended.
6) Will you be overclocking?
Probably so, dependent upon the cooler size. The Voodoo case doesn't have alot of room between the MB and the side panel. I think about 6 inches (152mm) would be the absolute max height for a tower cooler.
24" Dell Ultra-Sharp at 1920 x 1200
This week or next
9) What features do you need in a motherboard?
Crossfire eventually, USB 3.0 would be grand and eSata (don't need 6g yet but I'd like to future proof it as much as possible)
Windows 7 Pro 64bit
Here is what I have come up with so far. Tell me if I'm uninformed;
ASRock P67 EXTREME4
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
SAPPHIRE 100312SR Radeon HD 6950 2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102914
Intel Core i7-2600K (or would an overclocked i5 2500k suffice?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
G.SKILL Ripjaws X Series 8GB (2 x 4GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
For $854.78 plus shipping and including a pair of 3.5" to 5.25" metal brackets.
$1,000
DVD burner
This week or next
Windows 7 Pro 64bit
ASRock P67 EXTREME4
