New i7 build for gaming!!!
High end Gaming, photoshop, school, web-browsing
~2000$ give or take a little
3) Where do you live?
Las Vegas NV
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I want to do an i7 920, and use the new Radeon HD 5870
The whole computer, I will get a screen if I can fit it in, but i have a lcd and tv to use that can hold me off.
I might put an i9 in it when the i9 comes out.
Gonna go to frys tomorrow and check cases out, and then check newegg when I get the rest of the money for the parts.
None but the DVD burner in this computer. Everything else will be brand new.
6) Will you be overclocking?
Probably, this will be my frist overclock though.
Currently I have 19" crappy hp monitor 1280x1024
or my 42" tv
Planing on getting a 24" with a 1920x1080 screen res.
With in the next month or two.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support?
Mainly crossfire, as I may eventually get another 5870
10) Do you already have a legit and reusable/transferable OS key/license?
No
Planning on getting Windows 7 ultimate when it comes around. I'll just use the release canidate or XP till then.
These are the parts I have in mind so far:
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Want to overclock it probably.
Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
Graphics Card:
Probably order this very soon so I can get it in by the time I get the rest of the parts.
Memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
Hard Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136351
Power Supply:
I'm not to sure how many amps I am going to need for all of this.....
Some of these things might change (You know, like a better version of a part might come out?)
I should note that my friend is building this for me, he is part of this forum to his name is Rahburt-33
But yeah, anything you notice a cheaper or better part for any of the above, just tell me so I can take a look at it.
You're using that Green 1.5TB for storage right? Cuz as a boot or OS drive, that drive would be a poor choice.
CPU, GPU, and mobo wise, you're set. PSU wise, all you really need is this PSU:
$120 - Corsair 750TX 750W PSU
Though if this Antec PSU is $100 when you start buying parts, I recommend getting it instead:
$95 - Antec Truepower New TP750 750W PSU
Hard drive wise for the OS, Go for either the WD 640GB Black or 1TB Black drives. If you still have a ton of cash left, get the Intel G2 SSD.
Which games do you plan on playing? At which visual settings?
Swap out the OCZ RAM for a G.Skill or Mushkin set that runs at 1.5V-1.6V.
If you're only going with one HDD for your system, get either the WD6401AALS (640GB) or the WD1001FALS (1TB) instead. With the Green series HDDs, you lose a bit of speed.
Cool I am still pondering about what power supply to get out of the 3 you guys linked, but as soon as I get the rest of the money I should be set
I personally don't think that Evga x58 board is worth spending $300 on. LE version will get to 4 GHz overclock just as well with D0 step 920.
If you are planning on using Eyefinity, you need a displayport display.
... Though if this Antec PSU is $100 when you start buying parts, I recommend getting it instead:
Argh, missed it. Looks like its back to $130. :(
Yes, go WD Black or SSD (better yet, go with 2 SSDs and throw 'em in RAID0). ;)
That TP New would have been a great deal... good quality PSU at entry level 750W price. :eek:
I agree w/ shiro... $300 is way too much for a mobo.
