New Hard Drive or More Ram?
IceDigger
I have a semi gaming pc at work and would like your input as to the best bang for my buck upgrade.
Here is the current computer specs.
P4 Socket 478 2.8GHz 1MB Cache
ATI Radeon x800GTO2 Stock
2x 512MB PC3200 RAM Dual Channel
2x 40GB 5400RPM IDE Hard Drives
I think a newer seagate SATA .10 hard drive would be better then Upgrading my ram to 2gb right now but not sure. What say you?
2gb of RAM would be nice, but upping to a seagate 7200.10 or a Raptor should give you a pretty nice performance boost over those 5400rpm drives. I think you would notice a decrease in loading times.
normally, i'd say ram, but yah, you're two drives are just too slow for my taste. upgrade to the 320gb 7200.10 seagate, and you'll notice a bit of performance increase. if you could upgrade the ram too, taht would be even better, hehe.
harddrives for sure
the 320g .10 are the best, or one of, the best G/$ out there.
Think?
He might 4get it's his PC!!!
Raptor are the best. Hands down. Do you need storage or speed. 2 GB is also nice. Maybe you can sell ur 2x512 and get a 1gb?
Get a new HDD - 1GB is enough for the average user. I personally wouldn't bother with the Raptor's tho given the price. A decent SATA drive should be sufficient and will either get you the same capacity for less money for much more capacity for the same money.
That gig of ram is probably plenty. I'd be pushing for the hard drive swap.
Even if you had the cash for a Raptor, for the same money or less, you could get a 320GB 7200 HDD AND another gig of RAM. I'd get the HD if I had to choose.
5400 rpm, holy cow batman!
i'll got with a hard drive, will make everything you do a lot more smoother
Like many people here, I'd suggest a new 7200 RPM SATA hard drive. You'll notice some decrease in boot time.
Just ordered a seagate .10 320gb hd.
Thanks guys.
Maybe next year if it's in my budget I'll upgrade the ram.
