justride said:http://www.newegg.com/app/ViewProductDesc.asp?description=14-145-078&depa=1
is that better than a 9600se?
CastleBravo said:People can be so unhelpful on these forums sometimes.
any used copies of a card that new being sold for much cheaper are probably defective.
CastleBravo said:God, read the damn question people. He says "under $150," and he gets NOTHING but over $150 answers. People can be so unhelpful on these forums sometimes.
You might be able to find a used 9800 Pro for that price. You might find one on sale on ebay by a reputable seller and get one for cheap.
In a NEW card, the best you will be able to do is a 9600 XT, it will run Half-Life 2 well and run about $130-140. The comparable nVidia card is the FX 5700 Ultra, but they tend to be overpriced and hard to find.
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-326&depa=1
Best bang for the buck at the low end is probably the 9600 Pro, a little slower than the 9600 XT, but alot faster than anything near its price (about $100).
http://www.newegg.com/app/ViewProductDesc.asp?description=14-127-152&depa=1
Yes, a 6600 GT would be better. But it will cost more like $200 new, and any used copies of a card that new being sold for much cheaper are probably defective.
