DarkStar_WNY
- Dec 27, 2006
Gaming, with the occasional minor photo editing. If I get time I would like to start messing around with video editing, but not in a major way.
Around $3.6k
Western NY USA
Case and everything that goes inside it, mobo, CPU, RAM, GPU, SSD, PS, CPU cooler, OS, etc...
No, starting fresh and will be redoing my current rig for my wife to use.
6) Will you be overclocking?
Yes.
The case I am planning on, a Caselabs SMA8 in gunmetal grey is currently unavailable. My plan is to air cooled this build for now and then build a custom loop for it once Caselabs starts offering the gunmetal grey again and I get an SMA8.
Currently 1080p but once I order the parts for this rig I will be shopping for a 1440p monitor, preferably an ultrawide.
Ordering parts within the next two weeks and building before Sept 30 (I am have back surgery on that day and want the PC ready to go before that as my recovery will be 6-8 weeks, which should allow me to make some progress on my game backlog)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Probably the only "need" would be SLI, as I plan to add a second GPU at some point
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No
There used to be a question about having a Micro Center nearby, and while there isn't one in town there is one about two hours away that I want to check out, so I will probably get my motherboard and CPU there, assuming the pricing is good when I'm there.
This is the build I'm been considering - I plan on getting a Caselabs SMA8 in gunmetal grey as soon as they are available again, SMA8 is not included in my prices below or in the budget above.
Intel Core i7-6700K 4.0GHz Quad-Core Processor
Corsair H100i GTX 70.7 CFM Liquid CPU Cooler
Asus MAXIMUS VIII HERO ATX LGA1151 Mobo
G.Skill Ripjaws V Series 16GB (2 x 8) DDR4-3000 Memory
Samsung SM951 512GB M.2-2280 Solid State Drive
Samsung 850 EVO-Series 1TB 2.5" Solid State Drive
Western Digital Black 3TB 3.5" 7200RPM Internal HDD
EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+
EVGA SuperNOVA P2 1200W Modular ATX Power Supply
Microsoft Windows 7 Pro OEM (64-bit)
The above comes to about $2875
I've also been considering changing out the CPU and mobo for the following
Intel Core i7-5930K 3.5GHz 6-Core Processor
Asus RAMPAGE V EXTREME/U3 EATX LGA2011-3 Motherboard
This would raise the price to about $3259 ($400 extra to move up to the 5960X)
Finally, since the case I planned on using for this build will not be available for at least a couple months I need to decide on a temporary case for this rig, which once I get the SMA8 I would reuse the temp case to build my wife a system in using parts from my current rig.
What are your thoughts on this build and the 6700K vs 5930K/5960X for a gaming rig?
Around $3.6k
Western NY USA
Yes.
No
