burned-ati
- Jan 27, 2006
Received all parts, took cooler off the HD 7770 video card and wiped off the old hard powder like thermal paste on the GPU, and applied Artic silver 5. I wiped off the corsair H60 water block and applied Artic Silver 5. Assembled the computer, running a push pull dual fan setup for the radiator on the H60. The computer booted with no issues. It has been overclocked and is a stable 4.5Ghz at full load CPU 57c Running OCCT And MSI Kumbustor simultaneously for 1 Hour.
Asus Radeon HD7770 Running 100% full GPU load/ And 100% FULL CPU LOAD 4.5ghz Video card did not exceed 41C after one hour of full system load. Running kumbustor and OCCT And overclocked to 1175Mhz Core/ and / 1250Mhz memory
I am still fine tuning the voltage for the cpu, no matter how high I get, even 1.2 volts I am unstable at 4.6ghz after 13 minutes running OCCT. Although, running at 4.5Ghz it is stable for as long as you want to run the test! So, I am still fine tuning for the lowest stable voltage at 4.5ghz for the coolest temp.
