Scroll_lock88
- Nov 13, 2007
Gaming
$800-900, can stretch a bit more if the gains are significant. Tax/Shipping not included
U.S. Grand Rapids, Michigan
Case, CPU, Motherboard, RAM, Videocard, Power Supply
Reusing a Samsung 840 EVO 500GB SSD, and DVD Burner.
6) Will you be overclocking?
No
1920x1200, Dell 2408wfp, 24"
As soon as possible
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No Particular Needs
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 7 Home Premium 64bit
Have absolutely no idea where to start, been so long since I've parted out a build that I do not know what to do.
Like was said in the answers, would like to keep it around 800-900, but I can go a bit more if its a significant gain in performance.
Thanks in advance
Gaming
No
As soon as possible
No Particular Needs
Thanks in advance
