Hello folks. Looking to build my first new PC for myself in over 4 years, and looking for some suggestions on some hardware. I plan on keeping this PC for at least 4 years, and would like to run everything (currently, and for at least the near future) at the highest settings possible while still at 60fps.
Gaming and general use. Games that I play are mostly the staples - Batman AC, Borderlands 2, Skyrim, Diablo 3, etc.
~800.00 with tax/shipping included for the parts that I need. This isn't a full build though, so I may not NEED to spend 800.00 for what I do need to meet my requirements.
USA. I live in CT, and the closest Micro Center is up in the Boston area, a good 2hr drive.
Mobo, CPU, GPU, RAM, Power Supply, Optical drive (DVD-R I think should be fine), CPU Cooler (not sure if I need or not based on my OCing below)
The only thing that I would consider re-using from my current PC would be an HT Omega Striker PCI sound card. Also, I have already acquired some parts over the past few months, all while on sale and based on recommendations from this forum.
Case: Corsair Carbide 400r
SSD: Crucial M4 256gb
HDD: Samsung F3 1tb
6) Will you be overclocking?
Probably, but nothing too crazy. I'm a novice to OCing, but have had a very mild OC on my current E8400 (3.2ghz to 3.33ghz) for a couple of years now. I anticipate the same with the new rig as well, but I definitely won't be doing any hardcore OC'ing. Therefore, I'm unsure if I would need a CPU cooler to accommodate a light OC or if the stock HSF will suffice.
Single monitor, 1920x1080
Within the next 2 weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, preferably with the proper input for the Carbide 400r's front panel connector. SATA 6gb/s for sure. UEFI bios would be cool, but not a requirement. I know that PCI slots are on the way out, but having one for my sound card would be nice.
I have already purchased a fresh copy of Win7 64bit
Here's what I've been looking at for some potential parts so far:
CPU: 3570k. I assume a 2500k would suit me just as fine as well too.
GPU: AMD 7950 2gb. My last two cards I have owned have been a 4850 and 5850 from Sapphire, but any recommended brand on the 7950 will be fine. I realize that a 7950 is probably just a bit overkill for CURRENT 1080p, but I don't mind splurging here to cover myself as best as I can for future titles.
PSU: Antec NEO ECO 520C 520W PSU. I think this is all that I would need, and it seems to come recommended from you guys in many standard builds. I don't ever plan on using more than one card to justify a higher wattage PSU, so I think this will suit me.
MOBO: Will definitely need help here, as I'm not up to speed on the current mobos.
RAM: Definitely 8gb (2x4gb), but so many choices. The only thing that I'm sure of is that I should not use anything higher than 1.5v. I see a lot of recommendations for the G.Skill Ripjaw series, and for Samsung as well.
CPU Cooler: Again, not sure if I even need one, though the CoolerMaster Hyper 212+ seems highly recommended.
And lastly, a few general questions:
First time using an SSD for me, so are there any special BIOS configuration or Windows settings that I need to be mindful of?
The Carbide 400r case comes with 2 intake fans on the front and 1 exhaust on the rear, with spots for 2 additional fans on both the side and top. Should I consider getting 4x 120mm/140mm fans to occupy these slots? If so, what would be some good recommendations for these additional case fans?
And lastly, for mounting the power supply, I believe the proper way for mounting at the bootom of the case is to have the fan blowing air up into case, rather than down. Is that correct as well?
Thanks in advance for any help!
HDD: Samsung F3 1tb
