New dell, seems wierd :)
Irishllama
So i got the 20.1 2007WFP. It seems like the sides are going in, in the middle and the bottom task bars are comming up a little in the middle, basicly all th e things with long straight lines look like they are going up in middle :O. Maybe it's just normal and I'm used to a CRT smaller :). I tried adjusting it, but I do not see anything to adjust to make it different, since I am using DVI, does not look like to many options.
wow what in gods name are you talking about lol. why not take a pic with a cam and post it :D
He is talking about the "pincushion" adjustment that you would have on a CRT.
picture dude. or maybe your old crt was really fat looking...
K let me go dig out the old digi cam lol, (I'm probaly just crazy fyi, first real LCD besides laptop)
If you're using DVI then the problem is most likely with your visual cortex and not your display.
If the CRT you were using before was really convex and you've only been using your display for an hour or so then it's probably your brain.
It was a HUGE crt, so that is probaly why :). Almost as big as the old sun 20 inch CRT's
Oh and UPS just came :)
