New computer not starting
shimq1
Hi, I finally built my new comp after 2 weeks of waiting for my case which had to be replaced cause it was defective. When I try to start the computer, nothing happens at all! The "DRAM Power LED" and "Standby Power LED" are on.
My specs are:
Sky Hawk/Eagle Tech Matrix PSR5605W-SL Silver 1.0 mm anodized Aluminum Alloy ATX Mid Tower Case with Motor Drive Door - Retail
DFI LANPARTY UT nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD
SAPPHIRE 100130 Radeon X800GTO2 256MB GDDR3 PCI Express x16
OCZ ModStream OCZ45012U ATX/BTX/PCI Express/SATA 450W Power Supply - Retail
AMD Athlon 64 3000+ Venice 1GHz FSB Socket 939 Processor Model ADA3000BPBOX - Retail
CZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZ4001024ELDCPER2-K - Retail
NEC Beige 1.44MB 3.5" Floppy Drive - OEM
Western Digital Caviar SE WD800JD 80GB 7200 RPM Serial ATA150 Hard Drive
Microsoft K99-00001 2-Tone PS/2 Wired Ergonomics Keyboard Mouse
BenQ FP91G+ Black 19" 8ms LCD Monitor - Retail
NEC Beige IDE DVD Burner Model ND-3540A Beige - OEM
What happens with the diagnostic lights? They're the red ones in the very lower left.
-clear CMOS
-Try the video card in the other slot (yes, this has screwed me up many times, I'll just randomly reset and it won't start, I have to switch the video card slots, and I can switch it back after if it does boot)
Oh, sorry, nothing happens, not just black screen. Doh. What was I thinking?
Try the power switch on the board itself?
Damn, someone at the DFI forum says I need a 480W PSU minimum and I have 450W. And I need true 24-pin, which I guess I don't cause mine is a 20-pin plus a 4-pin.
No, you're fine. They're retarded at DFI-Street. There are many people that simply refuse to go there for help because they just spew crap like that and they're usually snobs when doing so. 450W is plenty to run this board (assuming no SLI), no matter what they say. And 20-pin + 4-pin is fine, unless you mean 20-pin + the 4-pin aux, which is different than 24-pin. If it's just a 24-pin where you can slide the 4 pins on or off, that's fine.
Make sure the board isn't grounding itself out (the screws underneath are installed)
Also check the manual make sure your +5 or the power header is pulgged in right
Then reseat the memory module to make sure they are installed correctly
Also double check and make sure the vid card is right.
Does it not power the fans.
Does the power supply turn on for a brief second then turn off?
If it does the second one it could very well be your power supply i have had that happen to me before and it's happened on a new build.
Looking at this pic, it seems like you can add the 4-pin connection to the 20-pin connection and then stick it in the motherboard. Then there's another 4-pin connection which should plug into the motherboard in another area. If you have that right, disconnect everything but the power, CPU, RAM and video from the motherboard. If you get a beep, start connecting everything one by one to see which part is bad.
