New Computer Build, What Do ya'll think?
Not a fan of that case, and they're crazy expensive, but cases are 9/10ths personal preference, so...
Get the A-DATA RAM kit from NewEgg. It's the same price as at Fry's, but it has free shipping and a $20 mail-in rebate.
Again, the DS4 is OOS at NewEgg. ClubIT has a promotion code that takes off $10 from the price of the Q6600 and any Socket 775 motherboard. Here are the available P35 boards at ClubIT. (Oh, look... the DS4's available... but I don't think you really need it.)
What a coincidence... ClubIT is also has the cheapest price on the case that you're looking for.
Now that NVIDIA has released its 9800-series cards, have you considered getting one of those instead?
Yes the regular DS4 is OOS BUT the GA-EP35-DS4 is for sale. It's exactly the same as the GA-P35-DS4 but its more energy efficient. ClubIT and Newegg should have that board.
I concur with tiraides on everything else.
Ok well I took tiraides advice on the RAM and the Case, and even the card. (Cuz I like NVIDIA better).
And i got the mobo that Danny Bui suggested.
so New List.
Most of the parts from here
Heat Sink and Fan:
Heat Sink
Fan
Processor:
Processor
Case:
Case
Ok thats it!
And it totals at $1976.23. Nice job guys. with in my 2k budget.
oh wait one more thing, sound i go with 2.4 or 2.6 Processor?
Because the stats on the Apevias are likely pure bullshit, and the ones on the Yates aren't, and you have enough LEDs already. This (Apevia) is the same company that labels a 300 watt PSU as a 600 watt PSU that melts when you try to get 400 watts out of it. Zero exaggeration here.
alright, I'm in no position to question your judgment. haha. Yates it is.
900 Watt Tagan? Why man why? Hehe. You only have 1 x 9800GX2 card in a non SLI mobo.
1. The Tagan PSU is far from your best option in the price range.
2. The company is run by imbeciles, as evidenced by their response to unfavorable [H] reviews.
3. 900 watts is completely insane for your build. It likely won't use half of that at full load. A quality 550-650 watt unit would be plenty. Go with a 750 if you must be 'sure', but 900 is completely uncalled for.
A Corsair HX620 Modular with 50Amps on the +12V is more than enough for your setup at less than half the cost of that Tagan PS.
Yup, that's the one. NewEgg sells the Corsair pricier than other places because soo much people buy those line. It goes to show you how good these suckers are. Hehe.
That looks pretty good man. I guess you'll be getting that Thermaltake Case over that Coolermaster case?
yes....whats wrong with the tt one?
It's just that you listed the coolermaster case in your "Most of the parts from here" link and the thermaltake case under "case". Kind of confusing which case you're going for.
Yup, nothing wrong just wondered which one your going with.
do i have the go head to buy now? or are there still changed to be made?
opps! thats not the right one, that's the air cooling one, i want the liquid.
i found it, and it's all ordered! so I'll be putting it together soon! i just hope the 620w is sufficient.
No sweat man. 1 x 9800GX2 with only 5 fans, 1 x HDD, 1 x DVD and 2 sticks of RAM is not much for that HX620. The 5 fans only consume 21 watts total.
Here's an idea of another persons setup using a HX520 watt PSU which is lower and less powerful than your HX620 he has a Dual Core CPU overclocked, 2 x HDD, 2 x Optical drives, 2 x 8800GTX cards in SLI, 2 x RAM modules, 1 x sound card. All of this on a Corsair HX520 Corsair. The 2 x 8800GTX in SLI consume more power than your 1 x 9800GX2.
...but the above guy is pushing that 520HX to the limit. Constantly. And that's not good for it at all.
I have a quad OCed, 2 GTXs, 2 RAM modules, 1 HDD, 2 opticals. I pull 600+ watts at the wall under load. Even dropping 100 watts (which is very generous) for the dual vs quad, and ignoring that he has another HDD, I would never, ever recommend a 520HX for the above listed setup. Ever. If that guy switches to a quad, it's all over. A 620HX isn't really enough for me to be comfortable. That's 750TX territory, pure and simple.
The OP, however, should be fine with the 620HX.
