Hello,
So, the time has finally come for me to build a new PC. Plus I thought it would be wise to mention that I have been out of the building game for a little while. (however I do know my way around a computer).
This is mainly going to be a gaming rig, along with all the usual stuff...watching movies on PC, browsing, office work
I don't plan on doing overclocking (well not at the moment anyways)
budget = $2000-ish AUD (1,790.20USD) [already have Samsung 22" monitor and mouse]
OS = PCLinuxOS (main OS) & Windows XP (maybe Vista later on)
case = Coolermaster RC690 Black Midi-Tower Case (other cases I was thinking about were Silverstone TJ09 or Coolermaster Stacker 832. Main thing I want from a case is good ventilation and with RC690 which is SLI certified it should have good airflow. It can also host quite a few fans)
motherboard = Gigabyte GA-P35C-DS3R (I would like to have RAID as an option, not going SLI and as mentioned above perhaps some overclocking later on down the track)
cpu = Intel Core2 Quad Q6600 2.4Ghz Processor (I understand that there aren't many applications that fully utilize these CPU's, however my main reason for getting this CPU is the fact that it has 2x 4mb cache...not sure if thats a good enough reason)
ram = Corsair Twin2X 2048MB DDR2 XMS2-6400C4 RAM (2GB should be enough?)
video card = 8800GT of course (If I can get one...also, can someone recommend a brand such as Inno3d, XFX, E-VGA etc?)
storage = not sure whether I should go: 1x 74GB 10,000rpm (OS / games) & 1x 500GB 7200.10 SATA 16/32Mb cache (Storage) OR 2x 500GB 7200.10 SATA's in RAID0?
psu = a modular good brand name 750w PSU (suggestions?)
sound card = Creative Sound Blaster X-Fi Xtreme Audio PCI-Express x1 (ok choice? I only need to hear mp3's and game sounds. Is there a real benefit to using a sound card if on-board is available?)
keyboard = Logitech G15
optical = Asus DRW-1814BLT Lightscribe Black 16x DVD+/-R, 8x Dual Layer+R SATA Drive
network = on-board should be ok?
I realize that with Christmas coming up that some of the hardware manufacturers may reduce price of components etc, so would it be worth holding out for a little bit longer?
All suggestions and advice are very appreciated.
edit:
Also, I left of my original post...cooling...
The Coolermaster RC690 comes with 2 fans AFAIK
My thought was to add quite a few fans in there so there is enough ventilation. So, I am thinking of getting the following:
2x 120mm fans - top
1x 120mm fan - bottom
2x 120mm fans - left
The fans that I thought would work quite well would be these ones?
Coolermaster 120mm Blue-LED case fan twin pack, 1200RPM, w/3-pin power x3
That's a total of 7x case fans (2 included and 3 twin packs)
Also, when it comes to CPU fans I was thinking about either:
Zalman CNPS9700 NT large Copper cooler w/9cm fan, for P4 Skt478/775
OR
Zalman CNPS9500LED large Copper cooler w/9cm fan, for P4 Skt478/775
edit:
2x 120mm fans - top
OR
