New Computer Build Help!
So, here’s the story: last month my GeFroce 8600GT blew all of its capacitors which has given me the opportunity to update my decrepit system. Because it’s been so long since I’ve actually looked at this stuff, I could really use any advice on what to get.
This will be mainly a gaming PC. I’d like to be able to play all the recent titles, (ME3, D3, Skyrim etc.) smoothly on decent settings.
I’d like to keep the budget to $700. I have an Amazon Prime account, so shipping shouldn’t be a problem.
I live near Madison Wisconsin in the good old U. S. of A.
CPU, RAM, Motherboard, Power supply, Video Card, and Case
Disc drives, a 200GB IDE hard drive and a 250GB SATA hard drive
6) Will you be overclocking?
No
I currently have a 19” 1440x900 LCD monitor but I’m looking to upgrade to dual 22” monitors eventually.
Within the next few weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I’m pretty sure I’ll just need the necessary hard drive ports.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 pro upgrade 64 bit
No
Unfortunately, hardly any new motherboards these days have any IDE ports at all. In fact, most new motherboards have absolutely no IDE ports at all whatsoever. So, you will have to retire that 200GB IDE HDD. And you might as well retire that older 250GB SATA HDD as well since both drives are likely ancient designs that can't sustain more than about 50 MB/s on the outer tracks - less than one-third as fast as (or more than two-thirds slower than) the fastest of the current-generation HDDs.
As for the other parts, you will have to settle for a relatively low-end CPU in order to keep the total system cost under $700 (with a new SATA hard drive factored in the total).
Alright, well $800 wouldn't be too far out of my price range. Would the remaining $700 be enough to build a decent system?
Even with your $700 budget, a solid build is still possible:
$180 - Intel Core i5-2300
$85 - Intel BOXDH67BLB3 Intel H67 mATX Motherboard
$40 - 2 x Patriot Signature PSD34G13332 4 GB DDR3 1333 RAM
$172 - XFX HD-687A-ZHFC Radeon HD 6870 1GB PCI-E Video Card
$95 - Seagate Barracuda 7200.12 1TB SATA Hard Drive
$20 - Samsung SH-222BB/BEBE SATA DVD Burner
$72 - Antec High Current Gamer HCG-520 520W PSU
$50 - NZXT Source 210 Elite White with Black Front Trim ATX Case
Total: $714 shipped.
If you still want to spend the extra cash, go with the above build but swap out the HD 6870 for the faster HD 6950 2GB:
http://www.amazon.com/Sapphire-DL-D...7?s=electronics&ie=UTF8&qid=1337930480&sr=1-7
Thanks! This looks great.
The OP could always find an external USB enclosure and use the drives as extra external HDDs. I went this route when my laptop monitor and motherboard burned out and now I have an extra 500GB of storage for emergencies You can get one from Amazon for around $10 bucks. For example, http://www.amazon.com/EXTERNAL-HARD...1?s=electronics&ie=UTF8&qid=1337963787&sr=1-1. Or, like E4g1e said, you can just destroy and trash them if they will have no use.
That same sapphire 6950 is $200 +tax at the egg, should save a couple bucks if you dont like doing Mir
