New Computer Build Help
Aldaris
Hello everyone, i just bought a new computer, i built a 478socket system like a year ago, now im going with core2duo, but i awnna make sure that i get the wire management right, cos i'm gonna be overclocking, and i wanna make sure the airflow and everything is perfect, i'm gettin an asus commando, the e4300 core2duo which im hoping to overclock to 3.2-3.4, on air cooling, i buoght a zalman fan for the cpu, this is the case i bought http://www.newegg.com/Product/Product.asp?Item=N82E16811119121, i got a 8800gts i just wanna know, wat do i need to have good wire managment, my last computer was a mess, so i wanna make sure this one runs as smooth as it can...tell me wat do i need to have an excellent wire managment =D imma be building my computer 2morro around 6pm east =D so if anyone wanna help me thru the cam =D id be appreciated lol =D haha thank you neways =D
so yeah lol basically wat i need, is someone to show me or help me, in wire management =(
Go to the Case Mod Gallery in the Cases & Case Modding forum and look at the "rate my cables" thread.
I recommend you spend a little more money on a cpu with a higher multiplier and 4mb cache. Such as e6320(1.86 4mb 7Xmulti) or e6420(2.13 4mb 8Xmulti). Your case should be no problem for wire management or airflow. It might be the best case for airflow/space combo. Don't sweat it ;)
hey thx for da replies n yeah i aws gonna spend more on my processor but 2 friends told me that that cpu is pretty good =D http://www.xbitlabs.com/articles/cpu/display/core2duo-e4300.html for overclocking, and yeah i wanna make sure i get the wiring right, i already got 7 fans on the case, i just wanna make sure i don't mess anything up, cos since im gonna be overclocking, i wanna make sure my case stays cool =D, well if you guys can give me any further instructions on how to do it, like i dont kno if i gotta put the wire behind the motherboard, n if so how does that work how do u do it, im a lil bit confused =(
Well first of all, tell us what kind of case you have. Second, list all the parts you're gonna buy for your new PC, and third, do what burningrave101 suggested in his post.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131149 mobo
http://www.newegg.com/Product/Product.asp?Item=N82E16817182032 psu
http://www.newegg.com/Product/Product.asp?Item=N82E16811119121 caase
http://www.newegg.com/Product/Product.asp?Item=N82E16814121061 videocard
http://www.newegg.com/Product/Product.asp?Item=N82E16835118020 cpu fan
then i have 2 harddrives, 1 sata 1 ide, i have an ide cd writer, i have a pci sound card soundblaster live it, n thats about it./
thank you for your help in advance.
and i did take a look at the thread, but i wanna know if i have to make a hole to th emobo tray or how do u put all the cables behind it lol :x
howbout text/names instead of links? or both? lol. yes, i'm too lazy to click on the one link that matters, the case link, lol.
(1) Get a quality PSU. That is the last thing you want to save money on. Get a quality PSU (Antec, PC P&C, Enermax, Silverstone, Seasonic, etc) and (2) I would recommend an E-VGA 680LT A1 for the same price. Just my $0.02 ;)
You can save $20 on an 8800GTS by going with this;
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB PCI-E Video Card - $280
Don't go with that 9700 CPU Cooler. The Tuniq Tower 120 cool much better and is quieter to boot. I managed to find one retailer with that cpu cooler still in stock;
http://www.xoxide.com/tuniq-t-120-hsf.html
Don't go with a Rosewill PSU. They're pretty much a crap shoot. I recommend either this PSU:
XCLIO GOODPOWER 500W ATX 500W Power Supply - $50
Or this one:
http://www.ewiz.com/detail.php?name=PS-E5150GH
The only difference between the two is that the Enhance PSU is of a much better quality than the Goodpower.
The Goodpower is a good budget solution, the Enhance is good if you have a bit more money to spend. The Corsair would be the best choice, if you can afford it. The Antec SP2.0 500W is modular, but is as good as the Goodpower (same OEM, CWT). I think the SP2.0 is the cheapest good quality Modular, unless you can find a Sunbeam NUUO 550W for $60 like the egg used to have.
Get some thin velcro strips or zip ties. I dont like the tape method, but thats just me. You could cut a hole in the mobo plate to help run wires if you like. You could also get a sleeving kit to make your wires look nicer (case wires, usb header wires, psu -- if its not already sleeved, etc). Just bundle them up as much as you can and hide as much as you can.
if anyone wants to help me build my computer lol ul can add me to msn or yahoo imma start to build in it like 15 mins my msn is aldaris652@hotmail.com n yahoo is aldaris652 , and my aim is aldarisss id appreciate anytype of help lol =)
dis is the first computer i build by myself i believe its gonna take me around 241-0942-10924-12 hours lol =D and 10140924 headaches to get it right =D , the first oen i had me n my friend built it lol an dit was a socket478 well brb imma do the wiring now
lol
so i finally finish my computer, n i when i bootd,.. the lcd screen give me the CPU INIT error, everything starts up, fans n all the LEDS, but the monitor doesnt have a signal, is there anything i did wrong, could it be any of the hardware i used, or should i try to reassemble. to be honest i think i did everything right. so well any kind of help here would be appreciated.
Since you admitted to this being your first build, I would recommend double checking your wirings. It is possible that you have some of your wires going from the case to the motherboard flipped around which could cause the power on, no display issue you describe.
Also, make sure that the pci-express 6 pin power connector from the PSU is going to the video card.
well i know its my first build but everything went smooth, and well i forgot to say that in the back of the mobo in the LCD screen it says "CPU INIT", 2night when i get back from work imma reassemble everything, and make sure i get everything right, and if dat doesnt work imma pick an antec psu at bestbuy n try it out with that, and if that doesnt work, im guessin it must be the mobo
Oh, try to reassemble the PC outside of the case to make sure that the case isn't shorting out the mobo. You can start the PC outside of a case by shorting out (connecting) thw two pins that powers on the PC with a screwdriver.
Make sure you reseat the CPU correctly.
wat do u mean by the case shortin out the mobo :x, and yeah imma try to reassemble the cpu, n reseat it, cos i had the big ass zalman 9700nt on it hopefully its sumthin on my end, and not sum doa hardware =(
Try using the stock HSF to make sure that that 9700 isn't causing any problems. As for the case shorting out the mobo, some cases have a small buildup of ESD that will prevent any kind of video card from showing video.
well yeah
first thing imma do its imma take everything outta the case, to avoid any shortin outage lol, and then if that doesnt work imma try the stock HS/F, if you have any ideas on WHERE SHOULD I START LOOKIN and how should i move forward, id be awesome. =) ty very much in advance
hmm i also wana know wat r the things i MUST connect in order to boot up my computer outside the case, and wat i dont necessarily need =)
you don't need a hard drive or even a CD rom to boot up the mobo.
mobo on its cardboard box (NOT on top of its anti-static bag), cpu, cpu hsf, vidcard or onboard video, a single stick of ram, PSU (20 or 24 pin atx power plug, 4 ("P4") or 8 ("EPS") pin CPU connector), keyboard, monitor, and system speaker (if one isn't onboard).
okay so i tried to boot it up outside of the case, and still didnt work, i used the hs/f that came with my cpu and didnt work, i tried using an old psu i had 450W and it didnt work, (it had 20 pins on a 24 pin mobo<--- the old psu dunno if that makes a difference) liek everything lights up, even the led on the mobo lights up it show the CPU INIT , ONE MORE THING, the FAN in the video card, doesnt start right away like the cpu and the other stuff, it takes like 3 seconds to start? is that normaL?, i really dont kno wat to tihnk :(
