Need help making sure this will all work together, and how can I be sure everything will fit in the case? This is my first time building a computer myself.
Already alittle over-budget and undecided between q6600, q8300 and e8400
q6600 oem and q8300 are the same price on newegg right now
will probably OC alittle but nothing extreme.. plan/hope to use just stock fans
will be used for high-end gaming and probably 3d work w/ maya soon
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=10041311
I already have the video card and hdd
gtx 260 core 216
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150329
seagate 640 gb hdd
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148335
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? gaming, photoshop, maya
2) What's your budget? Are tax and shipping included? ~600$ for the parts I still need
3) Where do you live? U.S.
4) What exact parts do you need for that budget? see: wishlist
5) If reusing any parts, what parts will you be reusing?
6) Will you be overclocking? probably the cpu alittle bit
7) What size monitor do you have and/or plan to have? have 22" don't want a new one, just got this one
8) When do you plan on building/buying the PC? by the end of april
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? don't need CF, sli, or raid
10) Do you already have a legit and reusable/transferable OS key/license? will be getting vista 64-bit
gtx 260 core 216
seagate 640 gb hdd
