New Comp build for Tonight
Status
Not open for further replies.
bkershaw
I posted earlier today and that thread has been pushed farther down and is kinda of confusing I think so I wanted to clean it up so it would be easier to help me out.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc... I will be gaming, using Dreamweaver, and photoshop
2) What's your budget? 1500-2000 ( would like to keep it around 1500 if possible)
3) Where do you live? Florida
4) What exact parts do you need for that budget? CPU,PSU, GPU, HD, RAM, Mobo,
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. No I will not be
6) Will you be overclocking? yes
7) What size monitor do you have and/or plan to have? 2x Samsung 27" Monitors (have already want to run via hdmi)
8) When do you plan on building/buying the PC? Tonight
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Im looking at the Asus P8P67 Pro
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? yes Win 7 64bit
This is the build I have so far
This is what I was thinking please tell me what I should change
Monitor: 2x Samsung 27" (want to hook these up via hdmi; have already)
Case: http://www.newegg.com/Product/Produc...82E16811146058
Video Card: XFX 6950 (can i hook up 2 monitors via hdmi to this)
SSD:http://www.newegg.com/Product/Produc...82E16820148348
HD: http://www.newegg.com/Product/Produc...82E16822136533
PSU:http://www.newegg.com/Product/Produc...82E16817139009
Ram: G.skill Ripjasw 8gb (2x4gb)
Drive: Lg Bluray drive
Drive: Lg DVD burner
Mobo:Asus P8P67 Pro
Proccessor: I7-2600k or i5-2500k (I was told i should go with i5 but the i7 is only about 100 price diff is it worth it for the extra 100bucks?)
Locking this thread as you already have a thread asking the same question.
Status
