- Apr 26, 2009
Caselabs S8: Horizontal ATX
Release Date: February 17th, Pre-orders are $40 OFF until Feb. 16th.
Price: $359
Made in the USA
Pre-Order is now live:
http://www.caselabs-store.com/mercury-s8/
Use S8PROMO at checkout to receive the $40 off!!!
Exterior dimensions:18.74"H x 14.54"W x 19.03"D (476mm x 369mm x 483mm)
Native HDD capacity; 4 (+2 on MB tray mount but you loose SSD mounting. 1 HDD uses 2 SSD locations) (22 maximum)
Native SSD capacity; 4 (44 maximum)
Number of Flex-Bays (5.25'' bays); 9
PSU mounts: 1
Expansion slots: 8
Form Factor: mATX, ATX, **E-ATX, SSI-CEB MB tray size; 12.38" x 10.75" (315mm x 273mm)
Maximum radiator size: 120.3 (360)
Note: Exterior dimensions shown are for the case only. Rubber feet add .75’’ (19mm) to height, optional standard casters add 2.6’’ (67mm) and HD Casters add 3’’ (76mm)
** "E-ATX" motherboards such as the; ASUS RAMPAGE IV EXTREME, ASUS MAXIMUS V FORMULA/THUNDERFX and EVGA Z87 Classified will fit in this case. E-ATX motherboards such as the; Supermicro X7DAE will not fit in this case. Please cross reference the motherboard tray size with the motherboard dimensions from the manufacturer. If the dimensions of the motherboard are within the dimensions of the tray, it will fit.
The Flex-Bay System
The Accessory Mounting System
Quick Release Exterior
Removable Motherboard Tray Plate
Mod Friendly
Anti-Vandal Switches with Sleeved Cables
Drop-In Horizontal Radiator Mounting
Drop-In Vertical Radiator Mounting
Integrated Radiator Mounting
All Aluminum Construction
Case Color
Standard
Black or Primer Gray (primer gray is not a cosmetic finish)
Upgrade
White, Dark Gray (+$25.00)
Two Tone (+$35.00)
Form Factor
Standard
ATX
Upgrade
SSI EEB (+$10.00)
Rear Fan Mount
Standard
120mm/140mm Hex Mesh or 120mm Fan Hole
Upgrade
NA
Doors
Standard
Solid or Ventilated
Upgrade
Standard Window (+$10.00)
Standard Window with Ventilation or XL Window (all clear) (+$15.00)
Front Cover
Standard
Ventilated or Solid
Upgrade
Window (clear) (+$10.00)
Top Cover
Standard
Ventilated or Solid
Upgrade
Full Window (clear) (+$10.00)
Ventilated/Window (clear) (+$15.00)
36mm Ventilated (+$20.00)
36mm Ventilated/Window (clear) (+$30.00)
Top Chassis Mount
Standard
120.3 x 2, 140.2/120.2 (universal) x 2 or Drop-in (with no mount)
Upgrade
Drop-in 120.3 x 2, Drop-in 140.2/120.2 (universal) x 2, Drop-in 120.3 with window cut-out or Drop-in 140.2/120.2 (universal) with window cut-out. (+$20.00)
Power and Reset Switch
Standard
Anti-vandal Power and Reset switches with sleeved cables or no switches or cables (subtract $20.00)
Upgrade
NA
I/O Panel
Standard
None
Upgrade
USB 3.0 and HD audio(+$25.00)
Flex-Bay Options
Standard
Solid Covers - 2 triple, 1 double and 2 single bay covers
Upgrade
Ventilated Covers - 2 triple, 1 double and 2 single bay covers (+$10.00)
120.2 mount with 1 double and 2 single solid bay covers (+$20.00)
120.2 mount with 1 double and 2 single ventilated covers (+24.00)
140.2 mount with 2 single solid bay covers (+$22.00)
140.2 mount with 2 single ventilated bay covers ($24.00)
120.3 mount (+$25.00)
MISC Add ons
Test Bench Conversion kit (includes 1 front and 1 rear chassis section and 1 front cover) (+$60.00) ($79.95 separately)
Add a HDD cage (4 drive capacity not a Flex-Bay cage) (+$24.00)
SSI-EEB Motherboard Tray Option
Test Bench Conversion Option
Price: $359
Made in the USA
PSU mounts: 1
Expansion slots: 8
The Flex-Bay System
Mod Friendly
Case Color
Standard
Upgrade
Two Tone (+$35.00)
Form Factor
Standard
ATX
Upgrade
SSI EEB (+$10.00)
Rear Fan Mount
Standard
Upgrade
NA
Doors
Standard
Solid or Ventilated
Upgrade
Front Cover
Standard
Ventilated or Solid
Upgrade
Top Cover
Standard
Ventilated or Solid
Upgrade
Top Chassis Mount
Standard
Upgrade
Standard
Upgrade
NA
I/O Panel
Standard
None
Upgrade
Flex-Bay Options
Standard
Upgrade
MISC Add ons
