Hi all
I want to build a computer with a budget around $1500, hopefull can last me for at least 4 years. The machine will be mainly use for gaming and lots of multi-tasking
My plan is to purchase this computer now and add some auxiliary components as times goes on, mostly stuff that can be reused on the next big upgrade.
CPU
*Fan
DVD Burner
Case
Harddrive x2
RAM
Monitor x2
Motherboard
Power Supply
Video Card
Thats it for my list, if anyone has any comment/suggestion, fire away. I will keep a close look at the replys and modify my list as times goes on.
Thanks for all the inputs in advanced. Cheers!
CPU
$240 - Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
- I think I will go for the e8400, since the new upgrade is going to be a full upgrade anyway with the socket change at the end of year.And since I doubt the gamming or application will fully ultilize anytime soon
*Fan
- Seem a little pricey but it looks like a solid investment.
DVD Burner
- If anyone can suggest a better one, feel free. I am open to suggestion, I just picked this one base on price and performance listed on newegg.
Case
- This case may be a little bigger than what I hope, but then I guess the air flow will just be better, love the all silver look.
Harddrive x2
- Planning to set up a RAID0 configuration, should I toss in the extra harddrive now? or wait untill the price drop?
RAM
- This seem to be the best for bucks, heard nothing but good things so far.
Monitor x2
$265 - SAMSUNG 226BW Black 22" 2 ms (GTG) DVI Widescreen LCD Monitor 300 cd/m2 700:1(DC 3000:1) - Retail
- Going for 22", hopefully I can find a S series.
Motherboard
- They both have RAID controller internally, leaning towards the Gigabyte one since is cheaper
Power Supply
$115 - SeaSonic M12 SS-500HM ATX12V / EPS12V 500W Power Supply 100 - 240 V UL, CE, CB, TUV, FCC - Retail
- Read a couple more review on OCZ and Seasonic, it seem seasonic is more on the quiet side.
Video Card
- Any one know if I will need to buy another fan for the video card if I am looking for some moderate OCing? Anyone know if the Step-up program only apply to their best of the line video card? or it can apply to any card from eVGA?
