Ok, i have 2 seperate problems.... If you could provide any help for either of them, it would be greatly appreciated.
I just got a Maxtor 200GB SATA HD to go along with my 2 160's in RAID. I have a K8t Neo FIS2R Motherboard. The 160's are on the via controller, and i just put the 200 on the Promise Controller than it has. My problem is that no matter what i do, i cant get the hard disk to show up in Disk management. I have tried installing newer drivers, different drivers, everything.
In the bios, when i select the promise controller to just do SATA, it go into some DHCP boot agent, and won't do anything. Also when i Disable the VIA controller it does the same thing, so i can only start up if the promise controller is set to RAID, and the VIA controller is enabled (i cant find different options for the via sata controller). All cables are connected correctly, and the hard disk is spinning.
And for my other problem...
I had a NEC 2500A burner, that would simply not burn MP3 files, iTunes would give me a error #4000, and Nero would get stuck at 5% everytime. I traded in the 2500 for the 3500, and still the same thing. Ive tried getting a codec pack to make sure i had a mp3 codec, ive tried really slow speeds, and different media.
PLEASE PLEASE help me, ive spent hours trying to solve this junk.
