- Sep 6, 2006
I've been out of the game a loooong time. I used to know everything computer related and then life got in the way. Now I don't even know what the most current DX version is. It's time for a new system, so what better place to turn to than [H]!
Some gaming. Looking forward to Just Cause 3. It'd be nice to have a system that can play GTA 5.
I have 3 monitors for general computing, school and work. I don't game across all 3 and I don't plan on it. I do want to be able to drive all 3 from the same GPU if possible.
Max is $1000. $750 would be nice
USA, Columbus OH. There is a Microcenter 20 minutes away.
CPU & cooler, MB, ram, GPU, power supply
I will reuse my case and SSD. The power supply is an original Corsair HX620. It's going on 8 years old.
6) Will you be overclocking?
Maybe, depends on what cooling system I have. Anything will be an upgrade from what I have now and I may not need to
1920x1200, 24in
Within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI
support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing special. Most any motherboard is going to have what I need. I do not plan on using multiple graphics cards. Everything out there seems to have USB3 and SATA6
I have a Windows 7 & 8 key. I'll probably stick with 7 for now, see what 10 is like when it comes out.
1920x1200, 24in
Within a month
