New Build
Games of all kinds, web use, movies, photoshop and video editing. possible virtual machines.
$1500 - $2000 Shipping and tax will have to be included.
Upstate New York, United States.
Motherboard, CPU, Ram and Video Card, cpu cooler, case, hard drive, operating system.
Seasonic X Series 750w (ss-750km)
6) Will you be overclocking?
Yes
22 inch samsung 1680 x 1050
In less then 2 weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Usb 3.0 and SATA 6Gbs for future proofing. Possible interest in crossfire or sli dependent on cost.
No.
This is what i have put together already.
ASUS Z87-PRO or ASUS Z87-Deluxe or ASUS Z87-Expert (not sure which one)
CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model CMZ16GX3M2A1600C9 (hopefully able to over clock these)
Intel Core i7-4770K Haswell 3.5GHz LGA 1150
I have not decided on a SSD for operating system
Pioneer Black 15X BD-R 2X BD-RE 16X DVD+R 12X BD-ROM 4MB Cache SATA 15X Internal Blu-ray Burner BDR-208DBK
Microsoft Windows 8 Pro 64-bit - OEM
I have not decided on a Video Card
I have not decided on a CPU fan
Corsair Obsidian Series 550D Black Aluminum / Steel ATX Mid Tower Computer Case (that should fit one of the MBs I pick)
Yes
No.
