New Build
Impulser
I'm going to be using it for gaming, live streaming, and video editing.
My budget is around 1000$
3) Where do you live?
United States.
  • Power supply
  • Case
  • Motherboard
  • CPU
  • Cooling System
  • Memory
  • Primary hard drive
  • Primary optical drive
  • Video card
  • Operating System
Nothing, I want this is be a clean build.
6) Will you be overclocking?
Yeah, probably.
23" Viewsonic
When I can decide on what to buy!
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Crossfire and SLI support would be nice.
Yeah, I have a legit copy of Windows 7 64bit.
I have some more questions:
Do you live near a physical Micro Center or Fry's store?
Which games are you going to play? What are you using for video editing?
Out of curiosity, what's the model number of your Viewsonic monitor? Resolution?
Which edition of Windows do you have? Which version (e.g., OEM, Academic, Upgrade)?
I don't live near any Micro Centers or Fry's stores.
The games I plan on playing are Starcraft 2, Battlefield, and Crysis.
I plan on using Sony Vegas Pro 10.
I have Windows 7 Home Edition.
What's the resolution you're using for gaming? What level of graphics quality?
That's what I was afraid of.
Is the monitor part of the $1000 budget? Do we need to also include keyboard, mouse, and speakers?
What about the OS? You included it in #4 but then say that you have it in #10. Which is it?
I don't want the monitor included, and I have the a copy of the OS now. Sorry!
For the tower and tower only:
$325 - Intel Core i5 2500K and MSI P67A-G45 combo
$30 - Xigmatek Gaia SD1283
$60 - G.Skill Value Series F3-10666CL9D-8GBNT 2x4GB DDR3 1333
$245 - XFX HD-695X-ZNFC HD 6950 1GB
$117 - Crucial m4 64GB SSD
$50 - Samsung Spinpoint F3 HD103SJ 1TB HDD (included $5 off promo code EMCKCKB22, ends 7/14)
$19 - LG GH22NS50 SATA DVD burner
$50 - NZXT M59 - 001BK
$100 - Corsair TX750 V2 750W PSU (included $10 off promo code EMCKCKB33, ends 7/14)
$996 - Subtotal (not including shipping, taxes, or rebates)
Questions? Concerns? Comments?
Thanks a ton!!!
I just have a question, how much better is the i7 2600k compared to the i5 2500k?
Just wondering.
but again thanks, this helped a lot.
For gaming and streaming, virtually no difference between the two. However when it comes to Video editing, depending on the video editing/rendering application, the difference between the two CPUs is as much as 20% but sometimes as little as 10%.
The i7-2600K is generally faster than the i5-2500K, but even multiple benchmarks on the same program -- in this case, Sony Vegas -- fail to yield consistent results. For example, Legit Reviews, Overclock.net (a forum post), and Tweakers.net (using Google Translate) offer different numbers on the performance boost the i7-2600K provides over the i5-2500K.
If you use Vegas Pro 10 about half the time you use your computer, then the i7-2600K may be worth the $100 price premium.
