LGZdarkside
[H]ard [H]eaded
- Sep 19, 2002
I have a chance to buy a PC and could really use some help with the configuration. I want something fast and reliable (if possible)
Thanks
Gaming
$4,500
3) Where do you live?
USA
Case - I like the Thermaltake level 10 GT
Motherboard
CPU - i7 - six cores ?
Memory - 12 GB
HDD 1 - SSD - for OS
HDD 2-5 - Raid 1+0 - for everything else
GPU - 2 x Nividia 580 in SLI
BluRay burner
Power Supply - 1200 ?
none
6) Will you be overclocking?
no
27" or 30" - Maybe 3 x 24" in eyefinity? - needs to be included
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
SLI, SATA6, good on board sound
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes - Windows Ultimate 64 bit
Thanks
Gaming
$4,500
USA
Motherboard
Memory - 12 GB
BluRay burner
none
no
ASAP
