New build
pants55
This is an upgrade for my brother-in-law and he wants to put this together over thanksgiving weekend. I've been out of building for a while and just want to make sure this all looks fine.
This PC will be built for gaming (primarily Microsoft Flight Simulator) and also some Adobe Pro usage
I'm thinking budget will be between $1000-1100
3) Where do you live?
US of A
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, Mobo, Video Card, PSU, a couple case fans
I'm going to be using a beige case that my brother-in-law wants his PC in.
6) Will you be overclocking?
I wouldn't be against it but I'll have to see what kind of fans (size, #, etc) the case I am using will hold
22" and 42" lcds
Thanksgiving weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I'd like to have 3x channel memory and a crossfire or SLI enabled motherboard
10) Do you already have a legit and reusable/transferable OS key/license?
Going to get him a Windows 7 64-bit license but i'm not sure what flavor he needs. I'm thinking Home Premium probably should be fine, but Pro isn't that much more, and Ultimate isn't much more than that even.
Here's what I've picked so far:
Intel Core i5-750 - 199.99
ASRock X58 Extreme LGA 1366 Intel X58 - 169.99
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 - 159.99 - $10 MIR
SAPPHIRE Vapor-X Radeon HD 4870 1GB 256-bit GDDR5 - $164.99
CORSAIR CMPSU-750TX 750W - $109.99 - $20 MIR
Microsoft Windows 7 Home Premium 64-bit - $106.99
I'll pick up a tube of AS5 and a couple of case fans depending on what we need. How does this look? I'm kind of iffy about the motherboard, processor and OS version and just wondering what's appropriate. I'm just wanting something really sturdy since I'll be 3 states away from the computer and don't want issues.
Thanks in advance!
That CPU will not work with the motherboard you chose. The i5 750 is socket LGA 1156 while the entire X58 chipset is LGA 1366. So you'll need to up the CPU to the Core i7 920 if you want tri-channel RAM:
$280 - Intel Core i7 920 CPU
For $10 less, I'd recommend getting the XFX branded HD 4870 due to the lifetime warranty and far superior customer support:
$155 - XFX HD-487A-ZWFC Radeon HD 4870 1GB PCI-E Video Card
For $5 more, I'd recommend getting this better quality PSU:
$115 - Antec Truepower New TP750 750W PSU
TBH, I'm not familiar with sub $200 X58 motherboards. Socan't really help you there.
Also, will that case be able to fit the motherboard and video card? Any chance you can get pictures of the inside of the case?
WroNg CPU. You need i7 920 for that motherboard.
Edit: dangit it takes 5 mins to load, type, post on the phone haha
See, this is why I asked. That would have been bad to get the wrong socket. I swear I checked but yeah, haha.
If you have a Microcenter nearby, they sell the i7 920 for 199.99. They will also pricematch with virtually any online retailer including Newegg.
