New Build
Probably. Now, if they somehow stack 3+ GPUs into a single card, I doubt it, lol. PSUs won't last forever. Keep in mind, the corsair is only warranted for 5yrs. ;)
Ok, I might just stick with the 850 and be done for awhile. Only thing i really want to find is a volume control for the front
Heh, the 620W should last you long enough (5yrs) if you're sticking with single card configs. Did you ask logitech about replacing the control unit?
I am going to replace my case fans with this new build. They are almost 2 years old and i am sure its a good time to replace them. I have 7 120mm Fans currently. I am looking for good RPM and biggest thing is Air Flow. Any Ideas?
We normally recommend either the low-speed Scythe Slipstreams or the Yate Loon D12SL-12 due to their comparatively good performance and relatively low cost.
If noise isn't an issue, then get the medium or high speed Yates again. ;) You have 7, so its best to stick with Yates over Slipstreams, hehe.
Whats really surprising, with all those fans my case is not very loud. The Stacker is pure metal so it acts like a noise reducer. You can barely hear the pc running with all fans turned up to max
hehe, some people's ears are more sensitive than others'. ;)
i am sure having system's in my car's have helped that lol. Nothing like 140 db's bumping in the morning. Great wakeup. I have 4 JL 1000/1's pushing 2 12" DB Drive Platinum's in a ported box. The subs can handle 4000 watt's each, they are nuts. I had JL's before i got the DB's
Amps:http://mobile.jlaudio.com/products_amps.php?amp_id=440 (1100 Bucks Each)
Subs: http://www.dbdrive.net/products-platinum.php?overview=true&id=plt12wd&section=
Well.. it's obvious the GTX 295 will smoke the GTX 285 but, I feel it's a waste for a mere 22" display at 1680x1050 res. In your case, I wouldn't invest too much on a video card now since newer video cards from ATI/Nvidia are on the horizon. The most I would spend in your case would be $200-$250. Look at either the Sapphire Toxic Radeon HD 4890 1GB for $219.99 or EVGA Geforce GTX 280 1GB for $249.99 Besides, your 8800 Ultra video card is considered overall slower than a HD 4850/9800 GTX+ video cards. You should see an overall performance boost of 20% at least by going with a 4890 1GB or GTX 280 1GB upgrade. I feel this is a pretty significant upgrade already.
Would i like the 285 if i go with a 24" or maybe even a 30" If that was the case should i get a 295 or wait a few months
Both are good boards.
Placed order today, got EVGA Board
Order Summary
. Qty Product Description Price
1
DISCOUNT FOR AUTOADD #3360
-$35.94
1
DISCOUNT FOR AUTOADD #2751
-$49.99
Shipped from CA, USA
. 1
EVGA 017-P3-1295-AR CO-OP Edition GeForce GTX 295 1792MB 896 (448 x 2)-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported ... - Retail
Item #: N82E16814130504
VGA Replacement Only Return Policy
$519.99
Shipped from NJ, USA
. 1
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
Item #: N82E16819115202
CPU Replacement Only Return Policy
$279.99
. 1
CPU Mag Gift - 6 free issues of CPU Magazine - OEM
Item #: N82E16800995076
Standard Return Policy
$35.94
. 1
EVGA E758-TR 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Item #: N82E16813188046
$269.99
. 1
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler - Retail
Item #: N82E16835103055
$59.47
. 1
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail
Item #: N82E16817139009
$139.99
. 1
Microsoft C8G-00004 Xbox 360 Common Controller - Retail
Item #: N82E16826105082
$35.00
. 1
Nvidia Gift Call of duty - World at war - OEM
Item #: N82E16800999088
Limited Replacement Only Return Policy
$49.99
. 1
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail
Item #: N82E16820227365
Memory Standard Return Policy
$99.99
. 2
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drives - OEM
Item #: N82E16822136284
$199.98
($99.99 ea)
Subtotal $1,604.40
Tax $0.00
UPS 3 DAYS $13.23
Order Total $1,617.63
This is too late, but blech on that soundcard. It's barely got a "decent" DAC.
Not sure he bought a soundcard... didn't see it on the list. $75 for a control pod on a $150 speaker system?!? jeez. Lame. I hope mine doesn't break any time soon, lol.
I did not end up getting a sound Card, i am going to just buy a new speaker system
RAID only guarantees the array's uptime. It doesn't back up anything -- any corrupted or damaged file will still remain in the RAID array.
If you truly want a decent back-up solution, I suggest a dedicated HDD (either internal or external) to be used solely for that task.
I was thinking about this last night, i have Norton Ghost, thinking of using that
Ghost will do an image, which will make it easy to get your system up and running if the RAID0 fails, but its not really a backup tool, though I guess you could figure out how to use it as one, lol.
For backup, I use external drives and just manually copy over what I need -- I don't need to backup much data, hehe.
yeah i have a tun of music and pictures i like to keep backed up. I setup Norton to do a weekly backup that amends the current one
Just got back from lunch and there is a Newegg box on my Desk :D:D:D:D:
Will get Pictures up soon. Got everything in today but the Video Card
*drum roll* Got everything in but Video Card, not bad for 2 day shipping from NJ :D
Waiting on Video Card to finish it all and clean up cables
