New build won't turn on.
Status
Not open for further replies.
I put the power switch the only place it could go. the mobo even has the the spot where I put "pwr switch" or whatever.
It would help if you told us what mobo and case you have.
Remove the power connector from the motherboard, turn the connector 180 degrees, and then connect back. Press power switch
If that doesn't work, remove the power connector from the mobo and jump (connect) the two power pins with a screwdriver. Remove the screwdriver when the system starts
Also, check the 4pin (or 8pin) ATX connector and make sure it's plugged in.
Status
